It is currently Tue Jul 22, 2025 9:00 am
 Post subject: What oil
PostPosted: Thu May 21, 2009 10:21 pm
I have a 77 clubbie with a 1275cc in it
i was just wondering what peoples opinion is on what oil i should replace the old oil with...brand? "think-ness" (if thats the right word)
what should i be look for and look to steer clear of?
PostPosted: Thu May 21, 2009 10:25 pm
I is a mookenik
mate i used to put kmx 20w50 in her. worked a treat... same as all my minis..
PostPosted: Thu May 21, 2009 10:29 pm
KMX from Kmart. Notice that they never have sales on it anymore??
cheers mate :D
PostPosted: Thu May 21, 2009 10:46 pm
yep KMX mate 6 Litres..its a bargin for the price and pressure is as good as the $$ brands
PostPosted: Fri May 22, 2009 7:32 am
Search is your friend.
http://www.ausmini.com/forums/viewtopic ... hlight=kmx
A few other links as well
By the way if G.R & DrMini uses KMX it must be good. I use this as well
"Boris" - '69 Cooper S Mk 2
PostPosted: Fri May 22, 2009 8:32 am
Must be alot of Mini's out there... haha
PostPosted: Fri May 22, 2009 9:16 am
poeee wrote:
Even without sales on, it's under 1/2 the price of the (now overpriced) Castrol Edge Sport 25W/50. 8)
Graham Russell runs it in all his engines on the engine dyno, including things like Ford BDAs running at 9500.
PostPosted: Fri May 22, 2009 10:46 am
they have 4L bottles as well now.
when i got one it worked out cheaper per litre to get the 4L
PostPosted: Fri May 22, 2009 5:48 pm
+1 more for KMX.
PostPosted: Fri May 22, 2009 5:53 pm
kmx being a cheap oil i stear clear of becuase cheaper oils use a cheap poor quialty base.
thats only my opinion. try not to ream me for it :?
i use Penrite HPR30
hold excellent oil pressure after a long open road drive.
PostPosted: Fri May 22, 2009 6:09 pm
i use Penrite HPR30
I used HPR30 for a lot of years. I have switched to a better oil.
KMX has less mayo in winter than HPR30.
It does not leak oil past the crank seal anymore.
Oil consumption has dropped.
Shell oil is good oil and it is event better in a KMX bottle. :lol:
PostPosted: Fri May 22, 2009 6:10 pm
Shame Castrol Edge is so expensive...it smells so nice.
It's like underarm deoderant for smelly mini engines.
PostPosted: Fri May 22, 2009 6:13 pm
so are you trying to say kmx is a relabled shell oil?
PostPosted: Fri May 22, 2009 6:14 pm
Yes.
