Nyloc nuts https://www.ausmini.com/forums/viewtopic.php?f=2&t=53519 |
Author: | Wombat [ Sat May 23, 2009 1:56 pm ] |
Post subject: | Nyloc nuts |
Does the thread have to pass all the way through a nyloc nut to be effective? I put some new nylocs - one each end of the swing arm spindle in place of the spring washer and nut but they are a bit deeper and the inside ones are about half a thread shy of coming all the way through. I have some large thick washers behind them and wondering if I should leave them out or go back to the original setup. |
Author: | drmini in aust [ Sat May 23, 2009 1:57 pm ] |
I'd go back to original, the washer spreads the load. |
Author: | Wombat [ Sat May 23, 2009 1:59 pm ] |
Ta |
Author: | drmini in aust [ Sat May 23, 2009 2:01 pm ] |
The nylocs are probably Chinese rubbish steel now anyway. Grade 4 or something. ![]() |
Author: | Harley [ Sat May 23, 2009 2:15 pm ] |
I don't cut corners on fasteners. I have mostly 10.9s on my car, still fairly cheap too if you buy in bulk. |
Author: | simon k [ Sat May 23, 2009 7:53 pm ] |
drmini in aust wrote: The nylocs are probably Chinese rubbish steel now anyway. Grade 4 or something.
![]() I bought what were supposed to be grade 8's from coventry, and when I torqued them up, the metal on the base of the nut actually started to peel - nasty |
Author: | micowen [ Sat May 23, 2009 8:12 pm ] |
could always try what I know as "prevailing torque nuts". The ones that when you look on them from the top, the whole with the thread isnt exactly round. Looks more like someone has put a nut in a vice and squashed it a little! They lock up nice and tight! |
