970 Cooper S engine https://www.ausmini.com/forums/viewtopic.php?f=2&t=5358 |
Page 1 of 2 |
Author: | doogie [ Mon Mar 07, 2005 7:01 pm ] |
Post subject: | 970 Cooper S engine |
Hey people, just wanting to know what parts are reqired to convert a S motor to a 970, is it just changing the conrods???? I belive the 970 rods are a AEG 177 parts no, i have 3 of them, no idea were the fourth on is. Is this all i need or do i need a different crank aswell? Any advice is welcome Doogie |
Author: | kazjim [ Mon Mar 07, 2005 7:19 pm ] |
PM Graham_in_Aus .. he's the resident Brit-spec Cooper guru .... he's especially find of the "little coopers" (997, 998) so he may shed some light on it J |
Author: | drmini in aust [ Mon Mar 07, 2005 7:20 pm ] |
Doogie, You need the rods, a 970S crank (~60mm stroke) and deck a 1275S block about 3/8" I think. Use an S block, as the deck is thicker than all the others. ![]() |
Author: | Mini Mad [ Mon Mar 07, 2005 7:24 pm ] |
These are the specs, jims right Graham is the man on these things... Specs indicate that it's just a shortened stroke we're looking at here: 970 S Bore/Stroke: 70.61mm x 62mm 1275S Bore/Stroke:70.61mm x 81.3mm You may also need to change the crank..I'm a fan of the little high revving 970S ![]() <edit> Doc cleared that right up ![]() ![]() |
Author: | doogie [ Mon Mar 07, 2005 7:25 pm ] |
What part no/castings on a 970 crank? Doogie |
Author: | drmini in aust [ Mon Mar 07, 2005 7:29 pm ] |
Ivan (Mini Spares & Repairs) owns a 970S. I think you will find 970S cranks pretty scarce. Not many were made. BTW Josh, they have bugger-all torque... you have to rev the nuts off 'em to get anywhere! ![]() Sorta like an 850 with more HP. (62, I think) ![]() |
Author: | doogie [ Mon Mar 07, 2005 7:33 pm ] |
Only $2500 new from the UK for a crank, yay this may take some convincing of my wife!!!! |
Author: | Mini Mad [ Mon Mar 07, 2005 7:35 pm ] |
Hehe, i'd be happy just revving it's nuts off ![]() ![]() That'll be about the same power as my 1152? or slower with the loss in torque? |
Author: | kazjim [ Mon Mar 07, 2005 7:36 pm ] |
Could you Destroke a 1275"S" ? 3/8 is an AWFUL lot of stroke change, but you could have the crankpins welded and re-ground on a smaller base circle..... be less than $2500 I'm sure..... J |
Author: | kazjim [ Mon Mar 07, 2005 7:37 pm ] |
Josh, Torque wins on the track... HP wins at the Bar ...... J |
Author: | drmini in aust [ Mon Mar 07, 2005 7:38 pm ] |
Josh, I think your 1152 would have way more than 62 HP now, and it's definitely more torquey than a 970 would be.. ![]() Just remember- HP= torque x RPM.... ![]() |
Author: | Mini Mad [ Mon Mar 07, 2005 7:38 pm ] |
yea probably aren't too many people in the 'destroking' game..i'm sure there are alot of requests ![]() ![]() |
Author: | Mini Mad [ Mon Mar 07, 2005 7:44 pm ] |
damn you lot, look how many replies got in as i was typing ![]() yea, i didn't say i was going to get one..but i still want one (no not a HSV either).. ![]() |
Author: | kazjim [ Mon Mar 07, 2005 7:47 pm ] |
Crazy as it sounds, i actually thought of de-stroking a 998 Crank.... find some rods of the approximate dimensions from a motorbike, a small, light set of kawasaki or honda pistons..... 11,000RPM and 16Psi.... hmmmm But the thought of having a mini flywheel / clutch spinning at that speed scared me !! ![]() ![]() ![]() J |
Author: | drmini in aust [ Mon Mar 07, 2005 7:51 pm ] |
I've got a nice Hillman Imp crank sitting here, ~60mm stroke, might be a bit long end to end though. But it'd never break.. ![]() |
