It is currently Mon Jul 21, 2025 12:10 am
PostPosted: Mon Mar 07, 2005 8:24 am
Between myself and my father in law, we have 'quite a few' radiators now... :lol:
Do the roundy ones have the top outlet at the front of the vehicle, and the Clubby ones have the top outlet under the filler neck?
That's the only visible difference between all of them.
PostPosted: Mon Mar 07, 2005 8:32 am
The early clubman ones are the same as the roundie with the top outlet at front, the later model clubman had them under the cap neck.
Cheers Pete
PostPosted: Mon Mar 07, 2005 8:36 am
Cheers Pete.
Why was the change made, and which would flow better?
PostPosted: Mon Mar 07, 2005 9:40 am
I think the change was made so that they could fit the airpump for the pollution gear where the top hose would normally go and the Inlet on the head moved to the back..I don't think it would make much difference to the way it flows, and would depend on the condition of the radiator, but i could be wrong..
PostPosted: Mon Mar 07, 2005 9:47 am
thats logical :mrgreen: cheers Josh.
PostPosted: Mon Mar 07, 2005 6:29 pm
If you fit the early rad and thermostat housing, you can pretend your `78 Clubbie never had an air pump & its plumbing... 8)
Bit obvious otherwise with the old pump mount there for all to see.. :shock:
PostPosted: Mon Mar 07, 2005 9:08 pm
a-ha!! up there for thinking big Kev! :wink:
Shame all the clubby rads are recoed and the roundy ones look cr@p..... :(
PostPosted: Mon Mar 07, 2005 9:38 pm
I only recently saw all this pollution gear not too long ago, show's you how well it's governed..hell my car is a '78 and it's supposed to have all that crap..glad it doesnt though :mrgreen:
PostPosted: Mon Mar 07, 2005 9:43 pm
What would you expect from a Government that invents ADRs, forces manufacturers to comply with them & emission laws, then puts absolutely no testing procedures in place!
I bet I could remove the cat etc from my EA Ford (crap, it's probably full of crap, car might go harder!) and nobody would notice at rego time.. :wink:
