It is currently Fri Jul 25, 2025 1:02 pm
 Post subject: cars running shite
PostPosted: Sat May 30, 2009 4:59 pm
ive just done the timing, points and rocker clearences on meeni and now the car starts up.. runs a little rough for about 5 seconds then goes fine for about 30 seconds.. then goes lumpy again and stops
im an idiot so i cant work it out, ive tried messing with the timing etc but i dont want to make things worse so il ask here
anyone know what this is..
btw it drove to work today but was lumpy then cleared itself out.. but since i "tuned" it its a bit average.. i dont think its blocked fuel because it will start straight up again just runs bad then good then bad then stops
Potato
PostPosted: Sat May 30, 2009 5:01 pm
pretty generalised question, but still,,, Did you clean the new points contact surfaces before you fitted them???
PostPosted: Sat May 30, 2009 5:03 pm
yeah i did
sorry to be vauge but if i was able to explain it better id know what it is :lol:
Potato
PostPosted: Sat May 30, 2009 5:19 pm
That`s ok,,, i`m used to it :-)
no worries i`m just asking one question at a time so we don`t get confused
how did you do the rocker clearances? What method>?
PostPosted: Sat May 30, 2009 5:42 pm
the long and extremely hard to explain way lol.. i know i did them right ive done them alot, i think ive worked it out, timing was out by a fair bit... i did it wrong :oops:
running well now
Potato
