It is currently Mon Jul 21, 2025 12:06 am
PostPosted: Wed Mar 09, 2005 3:04 pm
I'm about to knock up a piece of electronics that will let you know if you leave your headlights on. It will cost around $12 plus postage and will fit up behind the ignition/headlight switches. If you turn the ignition off without turning the headlights off you will have to change your underpants :mrgreen:
David L
PostPosted: Wed Mar 09, 2005 3:07 pm
Thanks, but I wired my lights into the ignition in the first place, so they can't be left on.
PostPosted: Wed Mar 09, 2005 4:35 pm
OoOoOoO
I want one.. Is it just a matter of connecting it and youre done?
What about postage?
Oh and does it fit other cars..? :wink:
PostPosted: Wed Mar 09, 2005 4:52 pm
Jaycar also do one of these kits, but it is $24 unassembled.
http://www1.jaycar.com.au/productView.asp?ID=KC5317&CATID=&keywords=headlight&SPECIAL=&form=KEYWORD&ProdCodeOnly=&Keyword1=&Keyword2=&pageNumber=&priceMin=&priceMax=&SUBCATID=
While doing this you might consider fitting the delayed interior lighting (handy for finding ignition, etc in the dark)?
http://www1.jaycar.com.au/productView.asp?ID=KA1793&CATID=&keywords=interior+light&SPECIAL=&form=KEYWORD&ProdCodeOnly=&Keyword1=&Keyword2=&pageNumber=&priceMin=&priceMax=&SUBCATID=
PostPosted: Wed Mar 09, 2005 5:42 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
msc made a funny a mini interior light that works BWAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHA
makka
PostPosted: Wed Mar 09, 2005 6:21 pm
Yep - Interior light would be useful when finding your way
PostPosted: Thu Mar 10, 2005 11:57 am
IwannaMini wrote:
OoOoOoO
What about postage?
3 wires - one to earth - one to switched active of the ignition one to switched active of the headlight switch. fits any car Postage = $2.10
David L
PostPosted: Thu Mar 10, 2005 3:19 pm
how about knocking me up a temperature switch for my thermo fan - I found a circuit diagram and bought all the bits from dicksmith, but haven't gotten around to putting it together in the 6 months I've had it....
PostPosted: Thu Mar 10, 2005 4:58 pm
teh admin God
teh admin God
makka
Is one of them a smallish species of fish that share a mutualism type of relationship with a newt?? Of where the fish scales fall off and float to the surface fo the water, and the newt feeds on them, thereby not causeing the scales to be seen by predators of the BWAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHA so they will not be attracted to it. Bugger me i knew it all along Cause they seem to be pretty common?? Or am i dreaming again?
Sir Namibian CAMEL of MONGOLIA !!!
Vrilen Snyson Racing: Finding us all a Vrilen
Asparagus: Experience the versatility
