paints, clear and simple https://www.ausmini.com/forums/viewtopic.php?f=2&t=5368 |
Author: | minimark [ Tue Mar 08, 2005 2:09 am ] |
Post subject: | paints, clear and simple |
Hi, just sprayed my roof using acrylic, still needs another rub back and some clear to make it shiny. Just wondering if anyone had anytips with using acrylic as I usually use enamel for spraying but have gone the cheaper option so I can get 'Giovani' on the road quicker. I have never clear coated a paint job so any hints would be great. Cheers Mark |
Author: | J_A_M [ Tue Mar 08, 2005 8:05 am ] |
here is a great link that might help you.... Great Link to help you ![]() |
Author: | low n blown [ Tue Mar 08, 2005 9:33 am ] |
Clear coating does not give you a shine to your paint. In fact clear coating alters the colour sligtly. If you rub throught the clear coat it will stand out. You can get just as good a shine from the base coat with acrylic. Make sure you lay on plenty of paint (I usually do between 9 and 12 coats) rub back with 2000 wet and dry. Maguires has a range of polishes from Heavy cut, to medium cut, to fine cut and finish it with a swirl remover. It can be sealed with their wet look or Medallion polish. Dont be afraid to polish with each level a few times. take your time and you will get a show finish, that is dead flat. G. |
Author: | minimark [ Tue Mar 08, 2005 10:14 am ] |
Thanks guys will look into it. cheers Mark |
Author: | speedfreak [ Tue Mar 08, 2005 1:32 pm ] |
this is how i paint acrylic Paint the colour fist rub that back finly then spray clear rub that back 1500paper or higher then buff as sugusted before |
Author: | J_A_M [ Tue Mar 08, 2005 2:45 pm ] |
I have NEVER used clear on non metallic base colour. |
Author: | MiniK [ Tue Mar 08, 2005 2:59 pm ] |
J_A_M wrote: I have NEVER used clear on non metallic base colour.
What about on metallic base coat then? ![]() |
Author: | drmini in aust [ Tue Mar 08, 2005 3:07 pm ] |
MiniK wrote: J_A_M wrote: I have NEVER used clear on non metallic base colour. What about on metallic base coat then? ![]() Yeah you do put clear over that (we're talking acrylic). But, when the sun's UV has burned the crap out of the clear in a few years, you will see why metallic acrylics don't last too well. ![]() My Fiat 124 Sport (medium blue metallic) looked sooo nice until the paint carked it.. ![]() |
Author: | MiniK [ Tue Mar 08, 2005 3:10 pm ] |
drmini in aust wrote: MiniK wrote: J_A_M wrote: I have NEVER used clear on non metallic base colour. What about on metallic base coat then? ![]() Yeah you do put clear over that (we're talking acrylic). But, when the sun's UV has burned the crap out of the clear in a few years, you will see why metallic acrylics don't last too well. ![]() My Fiat 124 Sport (medium blue metallic) looked sooo nice until the paint carked it.. ![]() An opportunity for real sleeper mode then eh? |
Author: | J_A_M [ Tue Mar 08, 2005 3:16 pm ] |
![]() I think Gareh took that a little too far with his Mini....! |
Author: | red078 [ Tue Mar 08, 2005 7:07 pm ] |
G'day, I have also done a bit of spraypainting, and have been told by a friend (an expert for over 35 years, who runs a bodywork), that clear is only needed for metallic paint, Tony ![]() |
Author: | jill200sx [ Tue Mar 08, 2005 9:42 pm ] |
ah well there ya go. I had planned on heaps of red paint followed by copious amounts of clear to ensure I got a nice deep shine.. seems I just need to polish the crap out of the red to achieve the finish I want that will probably last longer than if I clear coated it. ![]() Im using acrylic also, got the first paint on yesterday and Im very impressed with its coverage and finish from just the first "teething" coat. I can see 5-10 coats of acrylic, followed by the polishing method outlined above should bring it up beautifully ![]() |
Author: | gafmo [ Tue Mar 08, 2005 10:25 pm ] |
And He'll look dam Rosey I think ![]() |
Author: | jill200sx [ Tue Mar 08, 2005 10:37 pm ] |
Im thinking I'll take the rest of the week off and see just how Rosey it can get ![]() Nother tip Mark: Bought myself a tack rag today.. you have to get one, it removes all the dust between coats, better than a normal rag can do. $2.50 from Supercrap |
