Firewall insulation help needed https://www.ausmini.com/forums/viewtopic.php?f=2&t=53697 |
Author: | Matt68 [ Thu May 28, 2009 4:23 pm ] |
Post subject: | Firewall insulation help needed |
Hi, I have been thinking of getting some of the original style firewall insulation. My questions; 1) does anyone have pictures of what this stuff looks like installed? 2) Where do i get it from? I am interested in Good Quality, (not looking to save money by using nanna's knitted blanket etc ![]() I'm trying to beat my score from last year's Muster ![]() ![]() Cheers Matt |
Author: | BALLISTIC [ Thu May 28, 2009 4:27 pm ] |
Post subject: | Re: Firewall insulation help needed |
Matt68 wrote: I'm trying to beat my score from last year's Muster
Author: | Matt68 [ Thu May 28, 2009 4:40 pm ] |
BALLISTIC wrote: Matt68 wrote: I'm trying to beat my score from last year's Muster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Well, the firewall isn't as pretty as it used to be, so as well as giving a slight reduction in the cabin noise, the insulation might just move me up to a 7 ![]() ![]() |
Author: | BALLISTIC [ Thu May 28, 2009 4:45 pm ] |
You trying to beat Nicks score from last year?? ![]() |
Author: | Matt68 [ Thu May 28, 2009 5:11 pm ] |
yep ![]() ![]() |
Author: | winabbey [ Thu May 28, 2009 5:37 pm ] |
http://classicmotoring.net.au/cmos/inde ... cts_id=761 http://www.minisport.com.au/prod980.htm http://www.minis.com.au/minis/catalog/p ... cts_id=288 |
Author: | Roundie [ Thu May 28, 2009 6:11 pm ] |
hope you have uncluttered that engine bay of yours ![]() ![]() ![]() I know where to get some i will ring you later ![]() |
Author: | 64cooper [ Thu May 28, 2009 8:18 pm ] |
Matt I got mine from minisport in Adelaide. It looks and is made as per original and the under bonnet material is also close to original. |
Author: | peter1 [ Thu May 28, 2009 8:36 pm ] |
64cooper wrote: Matt
I got mine from minisport in Adelaide. It looks and is made as per original and the under bonnet material is also close to original. Ditto. |
Author: | low n blown [ Fri May 29, 2009 6:33 pm ] |
matt, I have a half a roll of the trim and an original pattern. Is very very close to the original trim for a MK 2. Happy to knock one up for you for cheap. PM me |
Author: | 1071 [ Sat May 30, 2009 6:18 pm ] |
Original to what is the question. Early roundnose is very different to Clubbie. A local trimmer sells Holden Ute tonneau cover vinyl which is a spot on match to the early S stuff. You can add a bituminised felt backing which is better then the old pale coloured fibre stuff (which you can't see anyway ![]() Cheers, Ian |
