It is currently Sat Jul 19, 2025 7:24 pm
 Post subject: Steering Issues
PostPosted: Thu May 28, 2009 7:39 pm
Hi Guys
I'm experiencing some pretty bad steering shakes from about 80km/h upward which is getting quite frightening!
I'm running 13x7 superlights but got a wheel alignment not to long ago so I imagine I don't need another one.
My mate has also just put spaced drums front and back on his mini and he is running 13x7's aswell and has recently experienced similar issues.
Anyone got any suggestions?
PostPosted: Thu May 28, 2009 7:44 pm
You both Need your wheels Balanced or if they have been done get it done properlly.
Otherwise something is lose in your suspention but Im betting you both had your wheels balanced at the same place :wink:
PostPosted: Thu May 28, 2009 7:45 pm
Sorry, as I always state, I am not a mechanic!
With that in mind, could it be something simple like one of your rims has spat a balancing weight? Or would this cause a constant shake irrespective of speed?
mooo, I'm a pig!
PostPosted: Thu May 28, 2009 7:50 pm
Gamfo is right, but also check your tyres for damage, flat spots or "eggs" lumps in your tread and check that you havnt got any damage to your rims, it can happen very easily. Jack em up an give em a spin an look for buckles or flat spots on the rim lip. Hope you get it sorted
PostPosted: Thu May 28, 2009 8:01 pm
thanks maxx.The reason I think its the balance as they are freinds and would expect them to both go to the same place for the Balance, and its the oviuse reason for shakinging over 80 k's
PostPosted: Thu May 28, 2009 8:48 pm
High heel ninja
Get the wheels balanced, or get someone who's in the know to check your front end, like John Leffler @ St George steering at Punchbowl.
Doogie
PostPosted: Thu May 28, 2009 9:36 pm
Doogie
As Doogie said...the FIRST thing I would suspect is the last thing done...your wheel alignment.
The other thing is maybe you have thrown a weight off a rim.
PostPosted: Thu May 28, 2009 10:34 pm
AAAAAH yes those crappy stick on wheelweights, they have a bad habit of falling off especially if the nuffy who put em on didnt clean the rims good enough :roll:
PostPosted: Thu May 28, 2009 10:48 pm
You have 13 x 7s on a spaced drum braked car?
What wheel bearings do you have?
PostPosted: Fri May 29, 2009 3:24 am
with 13x7 on spacers, I would be looking at the crappy felt bush in the LH side of the rack. With all the extra load it has probably flattened out . With big wheels I always use a nylon or acetal bush and replace the flimsy rack tube with a stronger aluminium one
www.minisprintgt.com
Users browsing this forum: No registered users and 72 guests
