ID on my new wheels please? https://www.ausmini.com/forums/viewtopic.php?f=2&t=53718 |
Author: | micowen [ Thu May 28, 2009 9:14 pm ] |
Post subject: | ID on my new wheels please? |
Hi AGAIN, not sure of the ID on me new mags. Can anyone ID them, or are they just a cheap remake of someone elses? ![]() ![]() |
Author: | doogie [ Thu May 28, 2009 9:42 pm ] |
There a cheap knock of of the superlight. only narrow & usually fitted with a 145 tyre, usually bought from Tempe tyres or similar places Doogie |
Author: | micowen [ Thu May 28, 2009 9:45 pm ] |
Correct, they do have 145's on them. Dont really care if theyre a genuine rim or not. Should look good though. Thanks Doogie. |
Author: | Mini Mad [ Thu May 28, 2009 11:16 pm ] |
the problem with them is the offset, they end up tucked underneath the guard and dont look right. |
Author: | bnicho [ Fri May 29, 2009 8:54 am ] |
Mini Mad wrote: the problem with them is the offset, they end up tucked underneath the guard and dont look right.
.... which is very useful if you want to run 8.4" brakes without flares. ![]() Cheers, |
Author: | micowen [ Fri May 29, 2009 4:59 pm ] |
Quote: the problem with them is the offset, they end up tucked underneath the guard and dont look right.
will using cooper stepped drums fix the problem and untuck them? |
Author: | Kennomini [ Fri May 29, 2009 8:27 pm ] |
With the discs up front it may the only way to tell for sure is to wack them on and hope they don't rub on the inner arch at the rear. |
Author: | drmini in aust [ Fri May 29, 2009 9:07 pm ] |
Stepped drums give the same front track width as S discs do. |
Author: | micowen [ Fri May 29, 2009 10:11 pm ] |
Ta guys, will just have to plop them on, and check it out. |
