It is currently Mon Jul 21, 2025 3:15 pm
 Post subject: chassis no.
PostPosted: Fri May 29, 2009 7:26 pm
Hi, looking for information about chassis no's went to get car roadworthy today and the bloke said he could not find the chassis no's stated they were stamped on car somewhere any help on this matter thanks
PostPosted: Fri May 29, 2009 7:28 pm
They are in different locations on different years.
What is your car and I will tell you where it should be.
PostPosted: Fri May 29, 2009 7:34 pm
Yeah it's a 1978 clubby
PostPosted: Fri May 29, 2009 7:40 pm
Too easy. The number should be stamped on the panel next to the radiator. It should say something like XNFAB18Y/10****
It should be the same number that is on the compliance plate.
PostPosted: Fri May 29, 2009 7:43 pm
found the one on compliance plate but there is none stamped near raditator
PostPosted: Fri May 29, 2009 7:51 pm
The panel looks like this....
PostPosted: Fri May 29, 2009 8:06 pm
thanks for your help as i found it under thick layers of paint and body filler
PostPosted: Fri May 29, 2009 8:08 pm
Cool, what does it say? Tell me the first bit and I will decode it for you.
 Post subject: cahssis no
PostPosted: Fri May 29, 2009 8:11 pm
no's are xnhab18y100872
