J_A_M wrote:
I scored a worked 998 with some good gear on/in it......I took the engine number prefix (99H791P) and asked a contact I have at the RTA whether this was OK for my Clubby.
His reply was
"The information supplied to us from the manufacturer, indicates that the engine number prefix of 99H791 was available in a 1975 model Leyland Mini.
If your vehicle was built prior to July 1976, it would then be a suitable engine.
The ADR's for emission control changed from ADR 27 to ADR27a in July 1976.
What a bummer.....JAM is a 8/1976.....
How stupid is the system though...the blocks are the same!!!!! are they not?
So I will have to strip this block and strip JAM's original block to transfer the internal goodies....
What a piss off!
Our Sept `78 block is 99H/889A, we had the same prob when we tried to get the engine changed. It's got a `74 1098 in it. As you say, bummer.
This also means if I want to fit a 1275 to this Clubbie it has to be an LS, or 1275 Moke, or later block.
Bloody rules... crap it's only a Mini, innit!
Highly illegal, but it's things like this that cause people to change engine numbers.. I saw a 1275 Mini that got registered last month, it has a Morris 850 engine number.
