bottom ball joints
https://www.ausmini.com/forums/viewtopic.php?f=2&t=53771
Author:  Leighton [ Sat May 30, 2009 8:07 pm ]
Post subject:  bottom ball joints
ive started assembling the ball joints and followed this how to:
http://www.youtube.com/watch?v=KyDE4oqbZnc
my dilema is here; with the spring assembled into the bottom ball joint and it all torqued up, the sivel pin is tightish (moveable by hand- just as it is in the video) is this normal or is there meant to be smooth movement like the top sivel pin.
just thought id ask you guys before i put my trust into the poems :D
thankyou,
Leighton
Author:  drmini in aust [ Sat May 30, 2009 8:10 pm ]
Yes it is normal for the bottom one to be stiff. If you can just move it all about by hand it is right.
The top one should have slight friction when torqued up (72ft/lb is correct).
Author:  Leighton [ Sat May 30, 2009 8:20 pm ]
ok thanyou for confirmation.
