It is currently Wed Jul 30, 2025 4:29 am
PostPosted: Sun May 31, 2009 3:33 pm
i have just put a new primary gear bronze washer on my 1275, but it was a rather tight fit, and now that its on it wont spin around. Does this matter?
i tried to take it off but i dont think it gonna come off to easy.
i also put the washers inner 45 degree angled side facing towards the block, is this correct?
i have a end float of .003 which is fine the book says between .003 - .006 but i hear you can run up to .010
77 Leyland Clubman
1293cc, LCB extractors, pulsar dizzy (recurved), cooper s disc brakes, 40DCOE Weber
PostPosted: Sun May 31, 2009 3:42 pm
The bronze washer doesn't have to spin, it probably will though when it's had a few heat cycles. Chamfer facing towards the block is correct.
.003" primary gear endfloat is good, over .006" is a worry, you do NOT want .010" on a rebuild. The clearance will increase soon enough... :lol:
PostPosted: Sun May 31, 2009 3:48 pm
this may sound stupid
but how does the primary gear work, i assume it transfers all the power from the engine through the idler gear into gearbox, but the primary gear just spins around on the crank.
77 Leyland Clubman
PostPosted: Sun May 31, 2009 3:53 pm
The clutch (when engaged) locks it to the crank.
