Brass ones are better than fibre. They don't fall apart with dirty oil.
The fibre washers they sell now are too thick and by your problem new brass ones are too.
One way to use them is get a few thou surface ground off the centre hexagonal spacer.
Last diff I did needed .008" off (.004" off each side). You just grind 2 opposite faces, put these towards the side gears.
<edit> you need to do a trial assemble with 1 washer missing, then use feeler gauges to measure to the spacer see what the remaining gap is.
Then compare that to spacer thickness.
You only want about .003"-.005" total clearance.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
