Mini-Ha-Ha's resuscitation https://www.ausmini.com/forums/viewtopic.php?f=2&t=5385 |
Page 1 of 8 |
Author: | drmini in aust [ Tue Mar 08, 2005 6:56 pm ] |
Post subject: | Mini-Ha-Ha's resuscitation |
Well it's all going to plan, I've got the 1360 auto block, rods, pistons & cam back, will get S crank back tomorrow. All being well I can start to screw it together this weekend. May be running again by Monday 21st. Yeehah! ![]() Sorry rice dudes.. no turbos, NOS, blowers, stroker cranks etc. It'll be just like before, but with `a bit more' power and a shorter (3.647) diff. ![]() |
Author: | 13secmini [ Tue Mar 08, 2005 7:43 pm ] |
Any hints on what cam will be used kev?? Ill pop around on monday if im in your area and give you hand if you want. How is barney going now after a couple of weeks of motoring. |
Author: | kazjim [ Tue Mar 08, 2005 7:51 pm ] |
I'm thinking that there will be a "Secret" GR Cam inside.... I'm thinking that the RE-13 has had a lot of developmen, and now its time to get a little more civilised, and even more powerful.... yes Kev ? hmmmm... i may have to wind some more boost in i think , 73, just aint going to cut it..... ![]() J |
Author: | Mini Mad [ Tue Mar 08, 2005 8:40 pm ] |
Hmm...nice ![]() I think GR has a new cam that's even bigger than the RE-13 ![]() Do you change how much power makes it to the ground when you change gearing at all? <edit> I'm thinking not..it just maximises the effective use of the power |
Author: | J_A_M [ Tue Mar 08, 2005 8:48 pm ] |
hehehe....pretty appropriate thread title, with easter coming up and all.... EDIT: Sorry...thought it said resurrection..... ![]() It is a kinda resurrection anyways...... |
Author: | drmini in aust [ Tue Mar 08, 2005 8:56 pm ] |
kazjim wrote: I'm thinking that there will be a "Secret" GR Cam inside....
I'm thinking that the RE-13 has had a lot of developmen, and now its time to get a little more civilised, and even more powerful.... yes Kev ? hmmmm... i may have to wind some more boost in i think , 73, just aint going to cut it..... ![]() J Nah don't worry- the cam will be the good old `revised' RE-13, same as Gaf and Mini Mad are running. But I'm using 1.5 rockers for more top end sizzle. There is a new killer street cam coming but it's not out of gestation yet. I'll shove one of those in my next motor, which will be a 1430.. ![]() |
Author: | Mini Mad [ Tue Mar 08, 2005 9:07 pm ] |
Why is it 'revised'?..you'll just be using the same cam? or was your original RE-13 grind different? |
Author: | drmini in aust [ Tue Mar 08, 2005 9:10 pm ] |
Mine was different. More top end, but less midrange. Now it's the same as yours. It'll still have good top end- I've had the die grinder in the head, again... ![]() |
Author: | Mini Mad [ Tue Mar 08, 2005 9:15 pm ] |
Haha, you just can't help yourself can you ![]() ![]() |
Author: | drmini in aust [ Tue Mar 08, 2005 9:17 pm ] |
Mini Mad wrote: Haha, you just can't help yourself can you
![]() ![]() My (turbo) head gasket is stronger than HIS (998) head gasket.. ![]() He can only run so much boost.... I hope! ![]() |
Author: | gafmo [ Tue Mar 08, 2005 9:56 pm ] |
Just you just lov it when it starts coming together... Congrats Kev..and I knew you would have a play with the Head ![]() |
Author: | 68matic [ Tue Mar 08, 2005 10:18 pm ] |
i am expecting it will be more impressive than Mini-Ha-Ha pre february 2005? hey doc, what sparked off his resuscitation? |
Author: | gafmo [ Tue Mar 08, 2005 10:22 pm ] |
Hay mate are you still going to do the Bench Dyno ![]() |
Author: | drmini in aust [ Wed Mar 09, 2005 5:50 am ] |
68matic wrote: i am expecting it will be more impressive than Mini-Ha-Ha pre february 2005?
hey doc, what sparked off his resuscitation? I was going to go the cheapo route of just replacing his cracked piston and fitting new rings, but by the time I strip it all down it's not worth it. So I'm building my spare motor to put in, it's now got 1360cc Hypatec pistons, S crank & rods. The old motor in car might yet get a stroker crank.. and be rebuilt to a 1430... for next time! |
Author: | Lillee [ Wed Mar 09, 2005 9:29 am ] |
Mini Ha Ha going faster than it already is! ![]() |
Page 1 of 8 | All times are UTC + 10 hours |
