Here's a trick https://www.ausmini.com/forums/viewtopic.php?f=2&t=5386 |
Author: | Chris [ Tue Mar 08, 2005 7:09 pm ] |
Post subject: | Here's a trick |
In the old days when all cars leaked oil we used to wrap the engine mounts in plastic to save them getting buggered by oil. Just a thought. |
Author: | bigel nigel [ Tue Mar 08, 2005 8:00 pm ] |
does it actually work have u done it before thats not a bad idea if it works cos i had to change one of my engine mounts (with engine in car) and it is not the easiest thing to do, very fidgity ![]() but not to worry i did it ![]() ![]() |
Author: | dewey [ Tue Mar 08, 2005 9:33 pm ] |
Is this because the oil eats away at the rubber in the engine mounts? |
Author: | willy [ Tue Mar 08, 2005 9:36 pm ] |
Thats correct. Motor oil etches natural rubber. This is why you should use "rubber grease" when greasing rubber parts. Quite simple when you think about it ![]() |
Author: | jill200sx [ Tue Mar 08, 2005 10:42 pm ] |
if you buy replacement engine mount rubber kits now, they are actually red polyurathane I think. not rubber anyway. I doubt they will be effected by oil. About $12 a set (4) from Repco does one engine mount. edit: I thought you were talking about the top engine mounts, but I just realise you may have meant bottom mounts.. I know nothing about them ![]() |
Author: | supercharged 850 [ Wed Mar 09, 2005 2:46 am ] |
big willy wrote: Thats correct.
Motor oil etches natural rubber. This is why you should use "rubber grease" when greasing rubber parts. Quite simple when you think about it ![]() Greasing rubber parts? Try some KY ![]() |
Author: | Chris [ Wed Mar 09, 2005 10:20 am ] |
I wonder if you can buy poly engine mounts. They would be the ultimate answer. Be bloody stiff though. |
Author: | min13k [ Wed Mar 09, 2005 11:18 am ] |
then you really would need KY makka |
Author: | simon k [ Wed Mar 09, 2005 11:29 am ] |
Chris wrote: I wonder if you can buy poly engine mounts. They would be the ultimate answer. Be bloody stiff though.
you can buy them, they're in miniworld etc. look pretty cool, they're yellow, and are in 2 pieces you put a pin through them. half goes on the subframe and half on the engine, they slot together when you drop the motor in.... |
