It is currently Tue Jul 29, 2025 11:05 am
 Post subject: Diff reassembly
PostPosted: Tue Jun 02, 2009 6:25 pm
I'm up to reassembling the diff.New planet gears, comp diff pin, washers, bearings.Spins nicely until I tighten up the crown wheel to the cage to specs.Then it doesn't move.
I take it thats not right and my new washers are a bit too thick.I'm using brass washers instead of the fibre ones.So go back to fibre or can I thin out the brass ones or is there something else.?
PostPosted: Tue Jun 02, 2009 6:46 pm
Thin fibre ones out of an early MK1 diff is the way to go :wink:
My bad :oops: It is the thin brass ones out of an early MK1 - I had to use them as the new fibre ones were way too thick - lucky I had an old MK1 diff here and I pulled them out and used them
PostPosted: Tue Jun 02, 2009 7:09 pm
Brass ones are better than fibre. They don't fall apart with dirty oil. :lol:
The fibre washers they sell now are too thick and by your problem new brass ones are too.
One way to use them is get a few thou surface ground off the centre hexagonal spacer.
Last diff I did needed .008" off (.004" off each side). You just grind 2 opposite faces, put these towards the side gears.
<edit> you need to do a trial assemble with 1 washer missing, then use feeler gauges to measure to the spacer see what the remaining gap is.
Then compare that to spacer thickness.
You only want about .003"-.005" total clearance.
