Diff reassembly https://www.ausmini.com/forums/viewtopic.php?f=2&t=53882 |
Author: | Drekkus [ Tue Jun 02, 2009 6:25 pm ] |
Post subject: | Diff reassembly |
I'm up to reassembling the diff.New planet gears, comp diff pin, washers, bearings.Spins nicely until I tighten up the crown wheel to the cage to specs.Then it doesn't move. I take it thats not right and my new washers are a bit too thick.I'm using brass washers instead of the fibre ones.So go back to fibre or can I thin out the brass ones or is there something else.? |
Author: | Wombat [ Tue Jun 02, 2009 6:46 pm ] |
Thin fibre ones out of an early MK1 diff is the way to go ![]() My bad ![]() |
Author: | drmini in aust [ Tue Jun 02, 2009 7:09 pm ] |
Brass ones are better than fibre. They don't fall apart with dirty oil. ![]() The fibre washers they sell now are too thick and by your problem new brass ones are too. One way to use them is get a few thou surface ground off the centre hexagonal spacer. Last diff I did needed .008" off (.004" off each side). You just grind 2 opposite faces, put these towards the side gears. <edit> you need to do a trial assemble with 1 washer missing, then use feeler gauges to measure to the spacer see what the remaining gap is. Then compare that to spacer thickness. You only want about .003"-.005" total clearance. |
