Brake booster with pedal box in 66 mini. dual brake lines?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=53908
Author:  NG [ Wed Jun 03, 2009 12:04 pm ]
Post subject:  Brake booster with pedal box in 66 mini. dual brake lines?
what do i need to do on my mini to make it work.
i have rover front disks 8.4, it all fits ok but i have a problem, one metal hose connects to the bottom T piece(2prongs for reverse light) , where does the other go coming out of the booster? rover ones are dual circuit?
Andrew told me some thing along the lines of having to plumb up for front or bakes together what ever is needed, this is a dual booster with cylinder attached.
my 66, well most older mini's have a one line system not a dual? now i i thought you could blank one? sounds like it could be a mad dangerous move.
I'm being a bit vague, sorry. I don't know so much about these boosters.
if anyone has hooked one up before let me know what had to be done & ill take it to a brake place to make sure it is done correctly.
this is on the end of my booster.
Ps mini is nice & dry cleaned & was pulled apart, everything & she kicked over on the weekend all is good!
