Nope, the thicker the better. I like using 4 or 6mm² marine tinned cable. But that Mini starter cable is good for around 250A...
Mini Mad wanted some decent 3M long jumper leads. All the ones you can buy at the various Bling stores are rubbish.
I made him a set, I used 25mm² welding cables with soldered brass lugs and 300A copper contact earth clamps (painted red and black) each end.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
