It is currently Sun Aug 10, 2025 2:30 am
PostPosted: Wed Jun 03, 2009 10:54 am
Hi guys,
Apparently, the pulley on UK Cooper S dynamo's (generators) was larger in diameter than regular Mini pulleys. Has anybody got knowledge of this difference?
Regards
Al
PostPosted: Wed Jun 03, 2009 12:39 pm
Yep, they were bigger here too. (I think maybe on the 997-998 Cooper also?)
That's why a Mk1 S takes a longer fan belt... 850 instead of 813.
Minis with alternators run an 825.
PostPosted: Wed Jun 03, 2009 1:04 pm
Hi Kev,
Do you have one you could measure at all please?
Regards
Al
PostPosted: Wed Jun 03, 2009 1:12 pm
Was there a difference between Cooper S dynamos and other Mini dynamos? - I have a generator at home I can measure but it was off an 850
David L
PostPosted: Wed Jun 03, 2009 1:28 pm
Hi Dave,
The dynamos (generators) were the same, it was the pulley that differed. I'm figuring the S pulley was 3-5/8" or 3-7/8" but hopefully someone will be able to have a measure-up.
Al
PostPosted: Wed Jun 03, 2009 1:43 pm
66S wrote:
Hi Dave,
Al
I did look in the Mini King parts book but he doesn't list it.
PostPosted: Wed Jun 03, 2009 2:10 pm
Hi Kev,
Knowing Joe Lucas, the correct pulley is likely to be a common one and shouldn't be too hard to find.
Regards
Al
PostPosted: Wed Jun 03, 2009 6:49 pm
I just measured mine and it is 3-7/8"
PostPosted: Wed Jun 03, 2009 7:53 pm
The Mini King
66S wrote:
Hi Dave,
Al
You are correct Kev I did not include the S pulley :oops: Originally there were two types of pulley, One for 850 - 997 & 998, Original Part Number was 12A34 which superseded to a cast iron pulley AYG 9029 The other pulley was for the 1275 Original part number 12A34
PostPosted: Wed Jun 03, 2009 9:41 pm
close your wallet i can't read the tape
PostPosted: Wed Jun 03, 2009 10:15 pm
I think the Balrog lives in there Morris...
PostPosted: Wed Jun 03, 2009 10:18 pm
See what happens when you stick a tape measure into an engine bay on a dark rainy night and let off a flash. I would bet that the spider webs are from redbacks. :lol:
PostPosted: Wed Jun 03, 2009 10:22 pm
i rekon some hand measurments would be more accurate :D.
PostPosted: Wed Jun 03, 2009 10:33 pm
Fiji wrote:
i reckon some hand measurements would be more accurate :D.
Here you go...
I still can't see how that will help though? :?
PostPosted: Thu Jun 04, 2009 5:55 am
Hmmm, dirt under the nails, must own a Mini.
Al
Users browsing this forum: Bing [Bot] and 86 guests
