It is currently Sun Jul 27, 2025 11:04 pm
 Post subject: Rear Trailing arms
PostPosted: Tue Jun 16, 2009 5:32 pm
i have noticed on my mini that one rear wheel is about 1cm further out than the other.
i have pulled rear subframe out to give it a freshen up, would the most likely cause of the rear wheel been out further on one side be a bent trailing arm pin?
also noticed one side had 2 shims in and the other didn't, could that have also been the cause?
77 Leyland Clubman
1293cc, LCB extractors, pulsar dizzy (recurved), cooper s disc brakes, 40DCOE Weber
PostPosted: Tue Jun 16, 2009 9:59 pm
where are the shims?? Or are they washers?? If you are in need of an almost complete dry subframe Im sure I can be of assistance.
PostPosted: Tue Jun 16, 2009 10:07 pm
Shims are often/sometimes used between the outer bracket and the subframe, to adjust to-in. But many cars have none.
Adding them gives less toe-in (or more toe-out).
