All Oz minis had a 1/4 BSP thread in the filter head, regardless of what filter type was fitted.
Mattsmadmini just bought a new spin-on one, and one of my 1/2" hydraulic hose kits. And found my 1/2 BSP x 1/4 BSP hose nipple fell right into it.
Thread in there appears to be an M14 fine thread or something.
I solved the problem by drilling and tapping it out to 5/8-18 UNF, the same as the block fitting.
I am posting this so people can BEWARE, your old Mini oil pipe flare nipple will not fit into these filter heads. Please check thread size before you buy.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
