Washer bottles. https://www.ausmini.com/forums/viewtopic.php?f=2&t=54230 |
Page 1 of 2 |
Author: | NG [ Sat Jun 13, 2009 4:43 pm ] |
Post subject: | Washer bottles. |
lame question i know. ![]() I'm just a bit lost with this. i would like to use a electric one or a pump at least I'm' running out of room to fit a aftermarket one with a pump. i don't really know how the original even worked, did it have a pump for the Windscreen washer squirters ? Do i just attach a small aftermarket electric pump to the original bottle? from super cheap? thanks for your help. something like this below with an aftermarket pump? is this what you guys do? http://www.minisport.com.au/prod723.htm |
Author: | poeee [ Sat Jun 13, 2009 4:45 pm ] |
The thing behind the dash is a pump. You pump it manually. Go buy a kit, you get a new bottle, leccy pump, switch and all. Mount it on the drivers side inner guard if you don't have a booster. |
Author: | NG [ Sat Jun 13, 2009 4:48 pm ] |
i have a booster! & Aircon. & the Kitchen sink. |
Author: | poeee [ Sat Jun 13, 2009 4:50 pm ] |
You'll find somewhere to mount it haha |
Author: | meeni [ Sat Jun 13, 2009 4:50 pm ] |
yeah they are very easy to fit and if your not worried about "concourse perfection" they are alot better.. mine is just mounted on the inner gaurd still a bit or room in there ![]() ![]() |
Author: | NG [ Sat Jun 13, 2009 5:00 pm ] |
i bought the same one you have. but the sink & aircon sits there lol. i don't think it's gonna fit. i guess ill just wait & see when i put the booster & Aircon back in see what space i have left. ![]() |
Author: | NG [ Sat Jun 13, 2009 5:01 pm ] |
the black plate to the left. or drivers side. where fresh heater pipe intake would be where did you buy that? I'm looking for one & with a hole in it like that would be perfect! |
Author: | meeni [ Sat Jun 13, 2009 5:12 pm ] |
i made it out of aluminium plate then just holesawed a chunk out of it.. pretty simple to do |
Author: | Davo111 [ Sat Jun 13, 2009 5:20 pm ] |
Mine is fitted in the boot on the drivers side, because I also have a kitchen sink under the bonnet, not that hard to run a 1/4 or 1/8 inch tube through from the back to the front and its easy to operate as well. Don't have to go too far for the power connection either about 6 inches........ ![]() |
Author: | drmini in aust [ Sat Jun 13, 2009 5:26 pm ] |
I have a Toyota washer bottle and pump in under the LH guard. Also a pair of metal trumpet Fiamm air horns in there too. |
Author: | Davo111 [ Sat Jun 13, 2009 5:27 pm ] |
No loss of pressure over the extra distance either. ![]() ![]() |
Author: | mini maxx [ Sat Jun 13, 2009 6:03 pm ] |
Ive got mine in the same spot dr mini has, Ita a d22 navara one with a long bent neck so its easy to fill |
Author: | IndigoBlueCooperS [ Sat Jun 13, 2009 6:58 pm ] |
Standard washer bottle with electric pump to the right of the radiator cap in the photo. ![]() |
Author: | Mick [ Sat Jun 13, 2009 7:04 pm ] |
Davo111 wrote: No loss of pressure over the extra distance either.
![]() ![]() Damn straight! I was using one of those pumps for another project and found that it was able to supply 14 psi....not bad for a crummy little pump I thought. |
Author: | simon k [ Sat Jun 13, 2009 9:01 pm ] |
IndigoBlueCooperS wrote: Standard washer bottle with electric pump to the right of the radiator cap in the photo.
![]() it all looks very normal in there, until you spot the extra clutch MC! |
