crown wheel @pinion https://www.ausmini.com/forums/viewtopic.php?f=2&t=54255 |
Author: | crabby [ Sun Jun 14, 2009 12:17 pm ] |
Post subject: | crown wheel @pinion |
Hi,would like to no if crown wheel @pinion out of a metro will fit the rod change gearbox as i am looking to fit higher ratio to my 78 mini to lower the revs any help will be great thanks |
Author: | simon k [ Sun Jun 14, 2009 12:23 pm ] |
the crown wheel and pinion are a matched pair - so to change the final drive ratio you need to change the pinion as well - engine out and gearbox off job so you need the pinion from the metro as well assuming your car is a standard 998 clubman, it should have a 3.44 diff ratio - I reckon it's the best combination of torque and high gearing, going any taller with a 998 will make it very sluggish what ratio does the metro have? |
Author: | crabby [ Sun Jun 14, 2009 12:26 pm ] |
Post subject: | crown wheel pinion |
ratio is 2.95 it come with pinion as well going into 78 mini with 1275 motor |
Author: | drmini in aust [ Sun Jun 14, 2009 1:14 pm ] |
Yep they will fit any Mini box. Rodchange or whatever. ![]() |
