It is currently Fri Aug 15, 2025 11:57 am
 Post subject: crown wheel @pinion
PostPosted: Sun Jun 14, 2009 12:17 pm
Hi,would like to no if crown wheel @pinion out of a metro will fit the rod change gearbox as i am looking to fit higher ratio to my 78 mini to lower the revs any help will be great thanks
PostPosted: Sun Jun 14, 2009 12:23 pm
the crown wheel and pinion are a matched pair - so to change the final drive ratio you need to change the pinion as well - engine out and gearbox off job
so you need the pinion from the metro as well
assuming your car is a standard 998 clubman, it should have a 3.44 diff ratio - I reckon it's the best combination of torque and high gearing, going any taller with a 998 will make it very sluggish
what ratio does the metro have?
 Post subject: crown wheel pinion
PostPosted: Sun Jun 14, 2009 12:26 pm
ratio is 2.95 it come with pinion as well going into 78 mini with 1275 motor
PostPosted: Sun Jun 14, 2009 1:14 pm
Yep they will fit any Mini box. Rodchange or whatever. :wink:
Users browsing this forum: No registered users and 207 guests
