removing cones. https://www.ausmini.com/forums/viewtopic.php?f=2&t=54261 |
Author: | micowen [ Sun Jun 14, 2009 3:11 pm ] |
Post subject: | removing cones. |
Hi all! Today I dropped the front subframe (thanks to all the tips!), and stripped all the bits and pieces that make the car bounce and stop! Problem is, the rubber cones and trumpets dont want to come out. One side I can wobble and stuff, but not get out. The other side is stuck rock solid, no movement at all! How do I seperate the trumpets from the cones, as I think that once this is done, I should be able to angle the cones out. I hope!! ![]() |
Author: | drmini in aust [ Sun Jun 14, 2009 3:39 pm ] |
WD40 around the end of trumpet, then use a BFH and chisel if you want to save the trumpets, an angle grinder if you don't. Then turn the old cones sideways, they come out `easier'. |
Author: | micowen [ Sun Jun 14, 2009 3:44 pm ] |
cheers doc, knew that you would rescue me yet again! ![]() |
Author: | Blokeinamoke [ Sun Jun 14, 2009 3:45 pm ] |
If you dont want the trumpets afterwards a bfh and a cold chisel will do wonders |
Author: | micowen [ Sun Jun 14, 2009 3:58 pm ] |
do hi-lo's replace trumpets? If so, then dont need the trumpets! |
Author: | simon k [ Sun Jun 14, 2009 4:38 pm ] |
micowen wrote: do hi-lo's replace trumpets?
yep... smash away ![]() |
Author: | micowen [ Sun Jun 14, 2009 5:04 pm ] |
I LOVE SMASHING THINGS!!! ![]() |
Author: | michaelb [ Sun Jun 14, 2009 5:57 pm ] |
You will probazbly find the old trumpets have started to corrode anhd will need replacing any way. but WD40 and gently hitting with a BFH should soon see them out |
Author: | micowen [ Sun Jun 14, 2009 6:07 pm ] |
Hi Michael. Once again, thank you for the windows! Anyway, yeh, had a quick look at the trumpets and saw not only corrosion, but a crack aswell. I dont think that I can hit gently with a BFH. If I use a BFH, I have to hit VFH!! ![]() |
Author: | gafmo [ Sun Jun 14, 2009 8:14 pm ] |
yer brake the trumput up and get a nice big screw driver betwen the cone and the subframe top, front and back, Pian in the buts. If you find the inside of the cone is corroded you can sourse other from the back end of a Clubby, They dont do much work back thier ![]() |
Author: | micowen [ Sun Jun 14, 2009 8:37 pm ] |
Thanks gafmo! By the way gafmo, am working on some bling that you may be proud of! More on that later. Keep watchin!! ![]() |
Author: | Oscar [ Mon Jun 15, 2009 10:55 am ] |
When you bung everything back together use antisieze. I've done this on everything on Oscar for over 30 years (coz I know I'm the bugger who'll be takin it apart next) and never had a thing that won't undo or come apart. ![]() |
