It is currently Thu Jul 31, 2025 8:15 pm
 Post subject: Bendix Gear Removal
PostPosted: Sun Jun 14, 2009 11:41 pm
I'm looking for some mid exam period garage relaxation and am rebuilding a standard mini starter motor including the bushes.
To get to the front bush I need to remove the bendix gear. I can see how to take it apart, the large spring is compressed and the circlip removed to allow the large washer and spring to then be taken off...
But I don't have a tool to compress the spring evenly for the short distance it will compress, so how does one do this easily in the home workshop?
PostPosted: Sun Jun 14, 2009 11:51 pm
I used 2 or 3 small clamps (engineers/toolmakers) around the spring.
Steve
1964 998cc Cooper
1971 Mini K x 2
1972 Clubman GT
PostPosted: Mon Jun 15, 2009 12:12 am
cable ties......
PostPosted: Mon Jun 15, 2009 9:42 am
This space for rent
Is there anything they can't do? :lol:
PostPosted: Mon Jun 15, 2009 9:51 am
Steve
That's a good idea!
Who showed you how to do that Cappa?
PostPosted: Mon Jun 15, 2009 1:35 pm
Cheers, I'll have a crack at it this afternoon ;)
Cable ties have nearly taken the role that gaffa tape used to fill :lol:
PostPosted: Mon Jun 15, 2009 2:49 pm
sitnlo62 wrote:
Steve
That's a good idea!
My Mini guru showed me that, I think you know him very well :wink: :D
Steve
1964 998cc Cooper
1971 Mini K x 2
1972 Clubman GT
PostPosted: Mon Jun 15, 2009 5:27 pm
I couldn't find any usefully small enough g-clamps, so I used a pair of vice grips, one on each side. They worked very well actually.
Now I will change out the front bush, it seems that the only bush that was available was the later M35J starter motor (later mini starter motor) bush. This one is thicker in sidewall and therefore needs to have the front cover replaced with a later type, or have the front cover's bearing journal machined out .050".
This suits the same adjustable reamer that is used for the rear radius arm bushes, which I happen to have here, so I will do just that.
Thanks for the help so far.
PostPosted: Mon Jun 15, 2009 8:06 pm
Hi you need one of these
They are a copy of the factory tool
PostPosted: Mon Jun 15, 2009 8:47 pm
I have one of these and have had it for over 30 years. It has done a lot of work. I bought it from a parts shop in London in 1978. It cost me one pound fifty I remember ! It is still going.
"Let us remove your "SHORTS"
PostPosted: Mon Jun 15, 2009 9:11 pm
yep great tools
I went to evening class and made mine, as a could not find one to buy.
Its quite any easy job if you have a lathe
Kiwiinwgtn
