help... https://www.ausmini.com/forums/viewtopic.php?f=2&t=54284 |
Author: | moustache [ Mon Jun 15, 2009 9:33 am ] |
Post subject: | help... |
hey all, so i'm driving in to work this morning, everything's going fine, no problems whatsoever, and then, out of nowhere, the car stops. the engine just stops running and won't start again. it's turning over, but not catching. i had a look at the oil and it was quite low, so i topped it up in the hope that would have some effect - it did not. my car is currently parked in the city (it's a miracle there was a space there) while i try and figure out what to do. any ideas on what is wrong here? |
Author: | simon k [ Mon Jun 15, 2009 9:37 am ] |
you've lost power to the coil... check the wires behind the ignition switch... they fall off sometimes. You can get home by putting a wire straight from the fuse box to the coil, then check everything over at home |
Author: | sports850 [ Mon Jun 15, 2009 9:38 am ] |
You need to check the basics , you've either run out of fuel (fuel pump died , wire off electric fuel pump etc) or run out of spark (wire off coil , hidden safety/isolation switch bumped , coil packed it in , points burnt out , wire off starter solenoid , ingition switch cactus etc ) . What does your mini have as far as fuel pump ? Check the connections to the coil and also the starter solenoid , also have you changed anything in the electrical system lately ? |
Author: | lil-ute [ Mon Jun 15, 2009 10:08 am ] |
this reminds me of another post where somebodys mini was flooded in a garage in queensland, karma is a wonderful thing ![]() ![]() |
Author: | blue_deluxe [ Mon Jun 15, 2009 10:15 am ] |
listen to sports850, a car needs fuel and spark to run. so check those first. Easy way to test is take a spark plug out and turn the engine over with the spark plug head earthed, if it sparks its fuel related. If it does spark work back to your fuel tank, check your float bowl to see if its got fuel in it, if it doesnt it could be your fuel pump. Working back til you find a fault is the best thing. This happened to me a few times in a suzuki sierra, got it home by using an air compressor as a fuel pump lol. |
Author: | Maxi23 [ Mon Jun 15, 2009 10:18 am ] |
lil-ute wrote: this reminds me of another post where somebodys mini was flooded in a garage in queensland, karma is a wonderful thing
![]() ![]() I have to agree there. I'm sure you will get it running again eventually. Have fun. |
Author: | weevel [ Mon Jun 15, 2009 11:30 am ] |
![]() ![]() This was the phrase you were looking for... for some reason i'm finding this hilarious! i hope your mini pulls through, though. |
Author: | Drexxle [ Mon Jun 15, 2009 11:52 am ] |
hehe, happened to me right in the middle of the Indooroopilliy roundabout. was the coil, then Steve from Mini Club comes around the corner in same colored car and helps me get it off the road. Walked up to repco bought a coil. Back on the road less than an hour later. |
Author: | moustache [ Mon Jun 15, 2009 12:59 pm ] |
weevel wrote: lil-ute wrote: this reminds me of another post where somebodys mini was flooded in a garage in queensland, karma is a wonderful thing ![]() ![]() This was the phrase you were looking for... for some reason i'm finding this hilarious! i hope your mini pulls through, though. i wished the poor bloke the best. i am a terrible person... |
Author: | NG [ Mon Jun 15, 2009 2:18 pm ] |
I'm sure your car will be fine just like mini ![]() |
Author: | sports850 [ Mon Jun 15, 2009 5:50 pm ] |
How did you go with it and did you find the cause ? |
Author: | moustache [ Tue Jun 16, 2009 8:30 am ] |
sports850 wrote: How did you go with it and did you find the cause ?
Ballistic came to the rescue! What a champ! Scott came and met me at the car after work. We think distributor cap is the problem? My car's at Scott's place now - coincidentally I had booked it in with him to go in to the shop today for a separate issue! |
