It is currently Sun Aug 03, 2025 1:21 am
 Post subject: Squeaky Front Suspension
PostPosted: Mon Jun 15, 2009 12:30 pm
This cold weather is both horrible to me, and to the car.
The dew in the mornings is now making everything squeak in the front.
I sprayed some WD in around everything suspension wise, and it went away for a bit, but a day or two later its back again, what can i spray in there that wont eat the rubbers and will stop the damn squeaky noise.
Its annoying every bump in the road the mini replies like a mouse on steroids.
PostPosted: Mon Jun 15, 2009 12:34 pm
Try front knuckle joint , just spray the wd40 into the cup where the knuckle on the end of the alloy trumpet/hi-lo sits in the upper suspension arm and see if that stops the squeak . The knuckle sits in a nylon cup in the suspension arm and when the nylon wears out it grinds into the arm squeaking all the way . If the wd40 stops the squeak then it's only temporary and means you'll have to change the knuckle joint soon .
PostPosted: Mon Jun 15, 2009 5:43 pm
Old school - shaved candle wax and paraffin oil mixed to a thick paste- apparently used in the Redex Trials to do the same thing.
PostPosted: Mon Jun 15, 2009 6:16 pm
This space for rent
My left-front squeaks like an old Holden.. it's got a seized upper arm pin and I CBF sorting it out because it'll probably have to be cut out...
