hard brakes https://www.ausmini.com/forums/viewtopic.php?f=2&t=54307 |
Author: | brett [ Mon Jun 15, 2009 9:12 pm ] |
Post subject: | hard brakes |
HI guys, I fitted new pads and rotors and had the brake fluid changed. I took it over mt glorious with 2 screaming women and because they demanded i brake for each corner, they over heated. now a few months later they dont have any bite? Can i take the pads off and hit them with an wire wheel? whould that remove any glazing or should I through them away and start over again??? There is no bad feeling through the brake pedal ( ie warped rotar) just it slows gradually and a hard pedal. |
Author: | meeni [ Mon Jun 15, 2009 9:16 pm ] |
what pads are they? sometimes if you run track day pads they dont get hot enough to work well in normal road conditions |
Author: | drmini in aust [ Mon Jun 15, 2009 9:27 pm ] |
Wire brush won't deglaze them properly. I'd hold them carefully on the side of a big grinding wheel. ![]() |
Author: | Morris 1100 [ Mon Jun 15, 2009 9:31 pm ] |
On the races cars we had a scientific way of doing de-glazing the brake pads, we would rub them on concrete. ![]() |
Author: | brett [ Mon Jun 15, 2009 9:43 pm ] |
cant remember but they could be race brakes, cause i went for high performance pads. |
Author: | mini_mad_matt [ Mon Jun 15, 2009 10:33 pm ] |
We just run them over the surface grinder at work ![]() |
Author: | brett [ Mon Jun 15, 2009 11:30 pm ] |
thanks guys going to a go at them this weekend! |
Author: | sports850 [ Tue Jun 16, 2009 7:11 am ] |
Just be careful of the dust Brett , I know they aren't meant to have asbestos in them anymore but treat it as if they do ... |
