Rotisserie https://www.ausmini.com/forums/viewtopic.php?f=2&t=54324 |
Page 1 of 2 |
Author: | cush [ Tue Jun 16, 2009 3:46 pm ] |
Post subject: | Rotisserie |
Oi doc.. Gimme some details on the rotisserie you had hooked up.. That looks the best of the ones i've seen. I have noticed that you don't use the front binnacle surround to mount it, why? |
Author: | cush [ Wed Jun 17, 2009 11:00 am ] |
Author: | Mick [ Wed Jun 17, 2009 11:21 am ] |
I'm not Doc, so apologies...but that's a lot of torque to put through 4 3/16 UNF spot welded nuts IMHO. And they are an odd pattern, easy to get out of alignment....but it would be nice when prepping to still be able to get to the engine bay crossmember if it doesn't have the rotisserie in the way...but its one of those little downsides I suppose. |
Author: | Angusdog [ Wed Jun 17, 2009 11:31 am ] |
Heck, I'll help you out. Ideally, you want it to carry the entire weight of the vehicle so you can check your tyre treads without bending down. You will need to remove any loose change from the ashtray. If it's constructed correctly, it doubles as a way of 'baking' 2 pac paint. Here's mine: The rain cover is ideal for NZ's inclement climate. ![]() |
Author: | mad-mk1 [ Wed Jun 17, 2009 12:19 pm ] |
Angusdog wrote: Heck, I'll help you out.
Ideally, you want it to carry the entire weight of the vehicle so you can check your tyre treads without bending down. You will need to remove any loose change from the ashtray. If it's constructed correctly, it doubles as a way of 'baking' 2 pac paint. Here's mine: The rain cover is ideal for NZ's inclement climate. ![]() lol ![]() |
Author: | Drexxle [ Wed Jun 17, 2009 3:16 pm ] |
hahahahahaha luv it ![]() ![]() ![]() ![]() ![]() |
Author: | mini maxx [ Wed Jun 17, 2009 5:42 pm ] |
pucken phunny ![]() ![]() ![]() |
Author: | michaelb [ Wed Jun 17, 2009 9:02 pm ] |
Looks like a New Zuland spay booth. |
Author: | drmini in aust [ Wed Jun 17, 2009 9:24 pm ] |
Here ya go cushman- It's not mine, it belongs to my local vet. It's stronger mounting it this way. ![]() Note the pole and bottom rail are in 2 pieces, it comes apart for easy transport. I brought it home in an EA sedan. BTW, this car is `Redmond', the 850 recently featured in TME magazine. Now done in the original Sunset Red. |
Author: | cush [ Wed Jun 17, 2009 10:58 pm ] |
any specs on construction/materials? |
Author: | drmini in aust [ Wed Jun 17, 2009 11:08 pm ] |
all steel 50mm x 3mm SHS, and 50x75 RHS x3mm uprights, except the main pipe- it was 5" water pipe. |
Author: | Angusdog [ Thu Jun 18, 2009 7:59 am ] |
On a slightly related note: ![]() An A-series version might be okay as a fish smoker, as long as you had twin carbs for heat control. Or you could go for the Weber option: ![]() |
Author: | jess [ Thu Jun 18, 2009 9:09 am ] |
Angusdog wrote: On a slightly related note:
![]() An A-series version might be okay as a fish smoker, as long as you had twin carbs for heat control. I want it! |
Author: | cbs [ Thu Jun 18, 2009 9:57 am ] |
Dr mini, stupid question maybe, but how do you get it up onto posts? lifted up by hand? ![]() |
Author: | Wombat [ Thu Jun 18, 2009 10:19 am ] |
Also - how is the rear end attached? - looks like a plate over the rear seat hole - how it it secured? |
