It is currently Fri Jul 25, 2025 10:58 am
PostPosted: Wed Jun 17, 2009 12:15 am
Daffodil 1275
Hi all
Does it matter what size rear brake cylinders I use with 8.4 inch disk. I think I have 3/4 rear wheel cylinders at the moment but am having trouble getting good braking. should I have 5/8. And could my rear brake bias valve be causing bad braking.
Cheers Phill
KillaWatt Converions
"E"Mini, 144volt, 600 amp, 86kw from the get go
PostPosted: Wed Jun 17, 2009 9:00 am
I'd be putting in 5/8" ones in.
