It is currently Mon Aug 04, 2025 5:13 am
 Post subject: ST bump stops
PostPosted: Thu Jun 18, 2009 8:05 pm
The large bump stops used by the special tuning kits for hydrolastic cars....I believe these are actually MG parts originally? Am I right?
Does anyone know the MG part numbers?
PostPosted: Thu Jun 18, 2009 8:07 pm
The rubber is an MGB rear bumpstop.
Brackets are not.
I would not fit them to the front unless you are building a rally car.
They give too much height and positive camber.
Fine on the rear... 8)
PostPosted: Thu Jun 18, 2009 8:35 pm
Thanks Doc,
I split the pair I have fitted on the rear arms because I didn't roll the seam they bump into over when I put it together...I saw it, but forgot to do anything about it...
All fixed now, MR rubber Mallet performs a very nice job of rolling them over a little 8)
