It is currently Wed Aug 06, 2025 9:25 am
PostPosted: Thu Jun 18, 2009 2:15 pm
Rover Cooper
I need to drop the dash forward to get my hands in to change the switch for the A/C , are there any traps and if so what, just need to drop it down, not remove it.
What is the correct procedure for doing this.
Thanks in advance. :wink: :wink:
PostPosted: Thu Jun 18, 2009 2:17 pm
Rover Cooper
Try this.
<mod edit: fixed it for you honey :)>
PostPosted: Fri Jun 19, 2009 5:35 pm
Rover Cooper
Doesn't anyone know how to drop the dash down from the top, Will have to get the Oxy out then. :roll: :roll: :roll:
PostPosted: Fri Jun 19, 2009 5:54 pm
cant you just undo the 3 dash hooks?
they are easy. both via the glove box or radio the last is pulled out via the far vent (unscrew it) put you're hand in & undo the other nuts. i have butterfly on mine turn by hand.
bit of a Faf around but the dash will just tip down or fall out depends how much you undo it.
hope that helps.
PostPosted: Fri Jun 19, 2009 7:21 pm
I never did it, but from what I remember having read, you have to undo the round air vents and access a bolt (I think) behind each as well as somewhere in the middle which means you need to get the radio and it's carriage out of the way.
PostPosted: Fri Jun 19, 2009 8:42 pm
Rover Cooper
Cheers gents, thanks will give it a go, was just a bit unssure of what might happen if I just attcked it. :oops: :oops: :oops:
PostPosted: Fri Jun 19, 2009 8:55 pm
Haven't done it before, but this is how the manual says to do it.
2008 Prado GXL
PostPosted: Fri Jun 19, 2009 8:57 pm
If it's just the air con switch, you should be able to get to it if you remove the radio.
2008 Prado GXL
PostPosted: Sat Jun 20, 2009 11:03 am
Rover Cooper
Thats what I was hoping, will give that a try first, when I get some time to myself. :wink: :wink:
