It is currently Thu Aug 07, 2025 6:33 pm
PostPosted: Fri Jun 19, 2009 3:35 pm
hey guys and gals i need to know what these holes are used for and if i need them befor i replace the floors.
1.
front of the car floor.
[img][img]http://i81.photobucket.com/albums/j211/badassmini/P1000098c.jpg[/img][/img]
[img][img]http://i81.photobucket.com/albums/j211/badassmini/P1000101a.jpg[/img][/img]
[img][img]http://i81.photobucket.com/albums/j211/badassmini/P1000093.jpg[/img][/img]
2.
rear of the car floor
[img][img]http://i81.photobucket.com/albums/j211/badassmini/P1000095b.jpg[/img][/img]
[img][img]http://i81.photobucket.com/albums/j211/badassmini/P1000090.jpg[/img][/img]
[img][img]http://i81.photobucket.com/albums/j211/badassmini/P1000094.jpg[/img][/img]
cheers for your help
dan
Cheers Dan
PostPosted: Fri Jun 19, 2009 3:43 pm
hi mate,
The holes in the front, next to the exhaust tunnel (second pic) are the drainage holes, on complete cars there are plastic plugs to stop water getting in, but if by some chance (or if your car is my car...) it does get water in it, pull the plugs out and the water drains out. same for second last pic.
no idea what the other things are, but they AREN'T jacking points...
78 Leyland Mini - Prince
PostPosted: Fri Jun 19, 2009 3:52 pm
Tin plate things are originally there for fixing the body to trolley / production line skid in the factory, a steel tongue slots in to the tin sleeve.
The diagonal ones at the rear of the floor are for Hydro protection plates, I would say your car is a 65 or 66 deluxe? :D
The others do serve as drain holes, the plugs would have been rubber on this earlier car.
Sir Alec! we are not worthy!
PostPosted: Fri Jun 19, 2009 3:58 pm
why are you replacing your floors, there doesnt appear to be anything wrong with them?????
PostPosted: Fri Jun 19, 2009 4:06 pm
The ones in front floors near tunnel are for Hydro protection plates also
PostPosted: Fri Jun 19, 2009 6:20 pm
Agree. Nothing a hammer & dolly wouldn't fix
PostPosted: Fri Jun 19, 2009 9:25 pm
I'm confused it got a push button start but a remote
And you have it up on its end :shock:
PostPosted: Fri Jun 19, 2009 9:41 pm
No push button start Jim. ALL Oz Minis got that floor bump, but only 850s got a hole in it and a switch. :wink:
PostPosted: Fri Jun 19, 2009 10:10 pm
hey guys thanks for all the help.
the front floors are worse then what they look but you are right there not bad but not good enough, the car is going to be a show car (not a trailer queen) and its gonna have flat sheet steel floors with bracing on the inside for strengh and the floors will be painted same colour as the body.
gafmo its not on its end its just they way the photo was taken it's on a rotisserie.
cheers dan
Cheers Dan
PostPosted: Fri Jun 19, 2009 10:36 pm
Early Coopers (997cc variety) use the hole where the 850 push starter button fits for a battery cable clamp mounting point. Keeps the battery cable well out of the way of remote shifts and exhausts etc.
PostPosted: Fri Jun 19, 2009 10:37 pm
from a old post ages ago i think we worked out it was a 67 or earlier.
these are the numbers if you wanna check.
firewall 25944
radiator coul M205 25464.
cheers dan
Cheers Dan
