My Reco Head Pics
https://www.ausmini.com/forums/viewtopic.php?f=2&t=54383
Page 1 of 2
Author:  72clubman [ Thu Jun 18, 2009 6:42 pm ]
Post subject:  My Reco Head Pics
this 12g940 head has had a port and polish,
1.40" inlet valves
hardened valve seats on exhaust side, and new double valve springs
and chambers reshaped and cc
the finish is so good i don't know if i should paint or leave it
Author:  meehal [ Thu Jun 18, 2009 6:58 pm ]
oh man that looks tasty.....mmm....droool
Author:  Mick [ Thu Jun 18, 2009 7:03 pm ]
It's a little sad after all that work, we go and bolt them on....all the pretty stuff is now on the inside, and will get covered in soot!
Author:  Convertible Mini [ Thu Jun 18, 2009 8:23 pm ]
Post subject:  Port and Polish !
That looks like the ports have not been touched only the chambers are cleaned up. Looks good though.
Author:  72clubman [ Thu Jun 18, 2009 8:29 pm ]
its hard to see with the valves in but its all been opened up a little, and cleaned up nice and smooth, its not a extreme port, if only i had the before photos intake and exhaust ports where heaps smaller than the manifold gasket, now they are the same size as the gasket openings,
i guess every head seams to be cast a little different, i may have had a real bad one
Author:  Brown Clubman [ Thu Jun 18, 2009 9:02 pm ]
my god that looks good! :shock:
I'd put a sheet of glass over the top and use it as a (very)small coffee table!!
Skender.
Author:  sgc [ Thu Jun 18, 2009 9:06 pm ]
Surely you're not going to ruin that head by bolting it onto an engine!?
Another example where they didn't come out of the factory looking that good 8)
Author:  gafmo [ Thu Jun 18, 2009 9:11 pm ]
72...Love it :wink:
Author:  moemoke [ Thu Jun 18, 2009 9:36 pm ]
That does look nice and its the next thing to get done to the moke,
Who did the work and roughly what did it cost?
Author:  TheMiniMan [ Thu Jun 18, 2009 9:56 pm ]
Nice clean mild head, well done,,, it`s often not much point opening the ports up much for a roady,,, & often quite detrimental (depending) the biggest restriction is at the valve & seat area,,, std-ish ports are are just fine for most road/rally minis
Nice job
But yes paint it right now as they go rusty very quick
Author:  Flute [ Fri Jun 19, 2009 11:13 am ]
Very nice, I might ask you one day where you got that done.
Author:  72clubman [ Fri Jun 19, 2009 11:25 am ]
yea it was a top job, i am a little worried about the chambers being 22cc, means i may end up with a final compression of around 10.5:1
which i dont know if that would even run properly unless on avgas
Author:  Lillee [ Fri Jun 19, 2009 12:41 pm ]
I run 10.5:1. Runs fine on 95, but better on 98
Author:  gafmo [ Fri Jun 19, 2009 8:30 pm ]
10.5 will be no troubles I'd hate to think what my 202 head mega skim on a 1152 is :lol:
Author:  drmini in aust [ Fri Jun 19, 2009 8:32 pm ]
Well it all depends what cam you use. The more duration it has, the higher C/R you can run.
With a stock cam, it would ping its head off (pun intended) on 95.
The Cooper S was 9.75:1 stock, and they were not real happy on 97 octane leaded Super.
