It is currently Sat Aug 23, 2025 6:26 am
Post new topic Reply to topic  [ 66 posts ]  Go to page 1, 2, 3, 4, 5  Next
PostPosted: Fri Jun 19, 2009 10:36 am
going gently around a left-hand corner near work this morning and it felt like something in the steering let go, it tried to keep going straight
I got it around the corner and pulled up, switched the engine off and looked over the front end and everything was in place.
I remembered what Doogie said about the last time his diff broke in a motorkhana, he had full drive on one wheel, the car just wanted to go in one direction - same kind of feeling.
I probably shouldn't have, but I started the engine again put it in 1st gear and tried to move it - had drive, no noises, but now it's jammed in 1st gear :roll:
bugger! gotta pull it all apart again :roll: :evil:
PostPosted: Fri Jun 19, 2009 10:43 am
You'd better move your bed into the garage as soon as you get home Simon , you know what your wife's reaction to the mini breaking again will be ...
While it doesn't sound good , I've got everything crossed that it will be something simple and not involving tiny pieces of metal that may have found their way into oil galleries .
PostPosted: Fri Jun 19, 2009 10:58 am
tell me about it :roll:
me too :(
PostPosted: Fri Jun 19, 2009 11:37 am
Hopefully - its "overlocked" in first gear and nothing else. The diff is a different problem.
Box off - sleep in the garage - sorry mate
Mike
PostPosted: Fri Jun 19, 2009 11:41 am
Time for a four pin diff mate, bad, but good at the same time :wink:
PostPosted: Fri Jun 19, 2009 11:55 am
yep - I'd hoped it would survive past August, dad is going over with Watto and I was going to get him to bring me one...
there was an obscene amount of swarf on the sump plug when I changed the oil before Hay, I expect there's more in there now
PostPosted: Fri Jun 19, 2009 11:59 am
Oh no! :cry:
PostPosted: Fri Jun 19, 2009 12:10 pm
You shouldn't go round corners gently in a Mini, what were you thinking?
Unless you have an LSD then a breakage in the diff would normally mean no drive at all. I can't imagine that being stuck in 1st is related, I look forward to hearing the news when you get it apart.
Pete
PostPosted: Fri Jun 19, 2009 12:11 pm
Simon. http://www.quaife.co.uk/
PostPosted: Fri Jun 19, 2009 12:27 pm
poeee wrote:
nup... all the best khana drivers use a 4 pin
PostPosted: Fri Jun 19, 2009 1:05 pm
but then where will she sleep? you got a sleeping bag mate?
78 Leyland Mini - Prince
PostPosted: Fri Jun 19, 2009 2:05 pm
Simon just to help you out with the missus I'll buy the non drivable car off you for say 3k hell I'll even let you work on it later :wink:
'62 Morris 850 (Marion)
'69 Vanden Plas Princess 1300
'71 Wolseley 1300
'74 Austin 1300 Countryman
'94 XJ6 Sport 3.2
'04 Rover 75 CDTi
PostPosted: Fri Jun 19, 2009 3:23 pm
ok, here`s my bet,,, the planetary gears (or one of them) has split into a couple (or a few) bits & one of those bits has flung out of the diff carrier & now jammed into the selector fork thingamyjig
PostPosted: Fri Jun 19, 2009 3:27 pm
ginger ninja
ginger ninja
I have no idea what you just said :shock:
but it kinda turned me on :lol:
sports850 wrote:
PostPosted: Fri Jun 19, 2009 4:03 pm
It's a Khana Kurse!
Users browsing this forum: No registered users and 301 guests
