Sonic Manifold won't fit in yer mini https://www.ausmini.com/forums/viewtopic.php?f=2&t=54409 |
Author: | MG Rocket [ Fri Jun 19, 2009 3:20 pm ] |
Post subject: | Sonic Manifold won't fit in yer mini |
Anybody know anything about this manifold? 4" long and takes 1.25" SUs and seems well made. Probably made for a N/S engine but I think it might fit my MG. So what would be the performance characterisics? More torque? What effect does having the ballance tube back up closer to carbies? ![]() ![]() ![]() |
Author: | TheMiniMan [ Fri Jun 19, 2009 4:24 pm ] |
Just makes it easier to get to the manifold nuts, |
Author: | MG Rocket [ Fri Jun 19, 2009 4:54 pm ] |
TheMiniMan wrote: Just makes it easier to get to the manifold nuts,
I take it you are referring to the position of the balance tube? Thanks Mr MiniMan.. yor the man ![]() |
Author: | simon k [ Fri Jun 19, 2009 5:30 pm ] |
MG Rocket wrote: TheMiniMan wrote: Just makes it easier to get to the manifold nuts, I take it you are referring to the position of the balance tube? Thanks Mr MiniMan.. yor the man ![]() big yellow Vizard has a bit of detail about the difference in balance tubes... nothing I can remember though ![]() |
Author: | drmini in aust [ Fri Jun 19, 2009 7:22 pm ] |
Looks a bit long for a Mini, maybe it was made for a Sprite or Morrie Minus? Check the flange angle- Sprites and Morries were usually 20°, and Minis 30°. |
Author: | MG Rocket [ Fri Jun 19, 2009 8:01 pm ] |
drmini in aust wrote: Looks a bit long for a Mini, maybe it was made for a Sprite or Morrie Minus?
Check the flange angle- Sprites and Morries were usually 20°, and Minis 30°. I'll check that in the morning. I think I could just squeeze it into the MG 1100 with a custom made airfilter. This is something I would like to do if one one or two of you tuning wizards could tell me what effect it could have on performance. |
Author: | sports850 [ Fri Jun 19, 2009 8:10 pm ] |
Theoretically a longer manifold is supposed to offer more torque , but in practice I'm not sure (there's something for someone to test with an engine dyno , same engine , same carbs , different length manifold ???) . I do know though that the photo of Peter Manton's 997 cooper in an older edition of TME shows a spacer of some form between the normal manifold and the carbs to get a similar length to your manifold . EDIT> crappy photo of the mag page but check out the location of the carbs compared to normal ![]() |
Author: | gafmo [ Fri Jun 19, 2009 8:41 pm ] |
I haveto ask..where the hell did you get it from ![]() |
Author: | d1ck0 [ Fri Jun 19, 2009 9:17 pm ] |
gafmo wrote: I haveto ask..where the hell did you get it from some Hedgehog was selling em.....
![]() Sorry. Dicko |
Author: | MG Rocket [ Fri Jun 19, 2009 9:34 pm ] |
![]() Well I work with this guy and he wanted to get rid of this BIG box of mini bits that he had sitting at the front of his house. In this box was a 1275 Clubman block, a cupla heads, a complete 1100 motor, some panels, a complete roundy grill, some fattened cromies all sorts of stuff and this manifold. I don't have a Mini but I have this very neat MG crying out for a bigger donk. |
Author: | d1ck0 [ Fri Jun 19, 2009 9:48 pm ] |
MG Rocket wrote: gafmo wrote: I haveto ask..where the hell did you get it from ![]() Well I work with this guy and he wanted to get rid of this BIG box of mini bits that he had sitting at the front of his house. In this box was a 1275 Clubman block, a cupla heads, a complete 1100 motor, some panels, a complete roundy grill, some fattened cromies all sorts of stuff and this manifold. I don't have a Mini but I have this very neat MG crying out for a bigger donk. |
Author: | gafmo [ Fri Jun 19, 2009 9:55 pm ] |
You have to love a score ![]() |
Author: | d1ck0 [ Fri Jun 19, 2009 9:59 pm ] |
I just remembered I had a similar setup on my A30 when I was a youngster. I got it off one of my Teachers' at School who had a couple of MG Midgets. Was a nice little setup, and it would have been too long to fit on a Mini. Don't think it had Sonic cast into it though so must have been somebody else's design. Dicko |
