It is currently Wed Jul 23, 2025 12:13 am
PostPosted: Mon Jun 22, 2009 7:25 pm
Wanted something to practice a bit of electroplating so thought the cover strip on the Starter Motor was a good candidate
I had wired brushed about a month ago but surface rust was showing up again.
Gave it another go on the wire wheel then cleaned it with Prepsol. - left the inside to compare.
This is the Setup with a Lab Bench Supply
Current was eventually set at 500mA for 1 hour
The finished artical - not as even as I hoped but good enough - a few 'golden' streaks and some dull patches otherwise it appears to be evenly coated.
And in place on the Starter Motor.
PostPosted: Mon Jun 22, 2009 7:34 pm
NIIICCCEEEE :wink:
Have a look at this.....
http://www.mckennasgarage.com/xke/jag_16.htm
Minimad
You can take the boy out of the racer.........but not the racer out of the boy!
PostPosted: Tue Jun 23, 2009 6:49 am
Nice work Wombat. Looks perfectly good to me.
Im here to learn!
