I definitely find lots of little charges to the credit card are easier to hide than one big one
superSeven wrote:
Or should I just put some cash aside once a month into an engine rebuild account?
if my wife didn't keep such an eagle eye on finances, this is what I'd be doing!
superSeven wrote:
I'd like to put in a RE13 cam, do I need a certain type (spider drive, key drive etc), or is this drive type only dependant on oil pump type?
there's only one type of oil pump readily available, and it's the spade drive type (has a spade shaped dealie that pokes into your cam) - Dr Mini sells adapters that go into a spider drive cam instead of the spider, so as long as you've got one of them then you're safe
But if you happened to find an A+ 1275 spade drive cam, then why not grab it (just check that the dizzy drives are compatible with someone like Josh @ miniimports). The cam can be wrapped in oily rags and won't go off - but what if GR makes an RE14!!
I had planned to buy and install the 4 pin diff later on this year, which would have been very handy to have in my cupboard right now. That's something I would have bought earlier on. Likewise I've passed up a few sets of S conrods that I now wish I had bought at least one set of
I've got one spare 1100S motor that I have robbed bits off - the primary gear is one item that springs to mind...
I'm always on the lookout for more 1275 bits - having plenty of spares is almost as good as cash in the bank, sometimes better because it can be hard to find that necessary part when you need it, but no fun when you have to cash out to pay for something
like Chong said, don't go buying pistons, rings, bearings because there are too many variables - if you buy .040" pistons but need to go to .060", then you're stuck with them
did I tell you that I won a
trophy?
