Rust in boot
https://www.ausmini.com/forums/viewtopic.php?f=2&t=54595
Author:  harry33 [ Thu Jun 25, 2009 3:15 pm ]
Post subject:  Rust in boot
Hi,
It finally occurred to me that it might be a good idea to look under the spare tire for rust:
There was also some under the battery:
Considering when I shine a light towards both these areas, I can look underneath the car and see a nice pattern of lights on the ground, I assume this rust is quite bad... Can people confirm this?
What should I do about it?
Harry
Author:  Lillee [ Thu Jun 25, 2009 3:23 pm ]
That's pretty bad dude... you can replace the battery box with a new one. The spare tyre well is going to be abit more work though
Author:  cd [ Thu Jun 25, 2009 4:25 pm ]
Same as mine.
Had to replace the whole boot floor & battery box.
Then found we had to cut the back off to get the new floor in. :x
Craig
Author:  gafmo [ Thu Jun 25, 2009 8:37 pm ]
Battery box is no chance and has to be replaced. On the rest of it Id get a wire wheel and a grinder on it, but Looks like its gone.
Author:  drmini in aust [ Thu Jun 25, 2009 9:52 pm ]
gafmo wrote:
Battery box is no chance and has to be replaced. .
Mine looked just like that. Was only rusted in the bottom.
I cut the bottom out but left 4mm all around, it was fine there, not rusty.
Then I cut a piece of 2mm steel plate to drop inside. Welded all around, lick of paint and it was fine.
That was 15 years ago, it's still fine. 8)
