Thread question
https://www.ausmini.com/forums/viewtopic.php?f=2&t=54602
Author:  Wombat [ Thu Jun 25, 2009 6:48 pm ]
Post subject:  Thread question
What is the size and pitch of the thread on the shaft of a Lucas 17ACR alternator?
Author:  gafmo [ Thu Jun 25, 2009 8:09 pm ]
are you asking the gauge of the wire from the Alt to the starter or inside the alternator (armiture) ?
Author:  Wombat [ Thu Jun 25, 2009 8:54 pm ]
Should have been clearer - the thread that takes the nut that holds the pulley and fan on the rotating shaft. I have an alternator here that some bright body in its history forced a nut of wrong thread on and damaged the thread and now that I have a new correct nut it won't go on.
Author:  drmini in aust [ Thu Jun 25, 2009 9:47 pm ]
PM Convertible Mini, Tony should know. :wink:
Author:  Convertible Mini [ Fri Jun 26, 2009 6:03 am ]
Post subject:  Thread size
There were many different threads on those shafts. So... If you have a correct nut take it to a bolt place... match a bolt to it and "voilas" there is your thread size. You could also use a thread file to clean the thread on the shaft. Thread files are magic tools. Or if you know the thread size you can re cut it on a Lathe. But is it worth the trouble ? For a little 17ACR.
