It is currently Wed Jun 25, 2025 2:12 pm
 Post subject: Thread question
PostPosted: Thu Jun 25, 2009 6:48 pm
What is the size and pitch of the thread on the shaft of a Lucas 17ACR alternator?
David L
PostPosted: Thu Jun 25, 2009 8:09 pm
are you asking the gauge of the wire from the Alt to the starter or inside the alternator (armiture) ?
PostPosted: Thu Jun 25, 2009 8:54 pm
Should have been clearer - the thread that takes the nut that holds the pulley and fan on the rotating shaft. I have an alternator here that some bright body in its history forced a nut of wrong thread on and damaged the thread and now that I have a new correct nut it won't go on.
David L
PostPosted: Thu Jun 25, 2009 9:47 pm
PM Convertible Mini, Tony should know. :wink:
 Post subject: Thread size
PostPosted: Fri Jun 26, 2009 6:03 am
There were many different threads on those shafts. So... If you have a correct nut take it to a bolt place... match a bolt to it and "voilas" there is your thread size. You could also use a thread file to clean the thread on the shaft. Thread files are magic tools. Or if you know the thread size you can re cut it on a Lathe. But is it worth the trouble ? For a little 17ACR.
"Let us remove your "SHORTS"
Users browsing this forum: Bill B and 100 guests
