It is currently Mon Jul 28, 2025 12:45 am
 Post subject: Inner A-panel removal?
PostPosted: Sun Jun 28, 2009 7:02 pm
Anyone removed inner a-panel with outer a-panel left in place?
Suggestions.
Trav.
PostPosted: Sun Jun 28, 2009 7:13 pm
it might be possible, but it'd me a major pain in the bum... you'll more than likely wreck the flanges on the old A panel trying to get the inner out
PostPosted: Sun Jun 28, 2009 7:22 pm
The inner panel flange is sandwiched between the outer panel flange and the fender flange. - so from the bottom of the window down to the wheel arch the seam is three layers with the inner panel in the middle - don't think it would be easy.
David L
Sorry forgot to mention that wings are off!!! :!:
PostPosted: Sun Jun 28, 2009 7:50 pm
Why do you want to remove it
PostPosted: Mon Jun 29, 2009 6:41 pm
its rotten in places. Bad places :!:
PostPosted: Mon Jun 29, 2009 7:40 pm
I think you will find after you the remove inner the outer will be just as bad I would be inclined to do both
