marks wrote:
Hi,
I want to tidy up the boot in my Mk1 67 deluxe but I'm struggling to find out how it came out originally.
I've only seen coopers with the boot board.
Was the deluxe the same?
Any links or photos would be great.
Mark.
Mark
I dont know about 67's but here is the boot/trunk of my 65 Deluxe.
The rubber mat is fixed to the top edge of the hatch with 4 round black top metal clips that push into holes in the panel, the welded holes in the mat are reinforced with calico glued to the underside of the rubber.
The rest of the mat is 'loose' across the battery box lid and spare wheel, etc and slots in under the fuel tank to hold it in place.
The ribbed rubber mat is shaped to fit the interior of the trunk and has a inch wide non-ribbed band running around the outside of the entire mat. It has a part number stamped on the edge of the mat. On my car the mat was pretty fragile areound the edges where it is closest to the boot door and it had become brittle with age and probably heat build up.
As Ive not been able to find new ones the same or any NOS that might work, I've cleaned the rubber down, treated it and carried out repairs since this photo was taken all withthe aid of hot sun and localised heat to make it easy squeezy
[/url]
