Sahig131 wrote:
hi guys,
just a quick question,
I hooked up my radiator yesterday and filled it with coolant. This morning i noticed that there was coolant in all 4 cylinders, it had leaked! argh
so Ive taken off the head.
after getting the head back from being milled a couple of months ago i noticed that the surface wasn't smooth, it has concentric grooves and feels a bit like 800 grit sand paper. I was told at the time that this is fine and it was from the old machine they were using...just wondering if this is the case.
thanks,
steve
Jut as a side note,,, What type/brand of head gasket was used??? Some of the early "monotorque" head gaskets (sivler with the blue lines) had an issue where the thickness of all the blue sealing lines varied greatly & lots of them leaked watwer out the sides
Another thing to look out for is to make sure that (sometimes) after heads have been machined "too much", & while tightening it down, the thread bottoms when the cyl head nuts on the studs (or bolts) & obviously then it wont be pulling the head down any further & may not be actually clamping the head down enough to seal,,, check thread depths & head thickness & add hardened steel washers if need be to combat that problem
I really don`t mind a swirly machined surface,,, it helps the gasket bite,,, just has to be clean & flat is all
