It is currently Wed Aug 13, 2025 8:09 am
 Post subject: disc brake question
PostPosted: Wed Jul 01, 2009 7:14 pm
currently running discs on the front and rear drums on the 1275. i get good pedal when braking but lack stopping power..... i dont have brake boosters
recently had my brake light pressure switch changed because my brake lights werent coming up ... can this have any effect one the brake performance if the incorect typre was put in.
 Post subject: Re: disc brake question
PostPosted: Wed Jul 01, 2009 7:26 pm
This space for rent
In a word... no.
Unless it's leaking fluid that is, but you'll notice that.
PostPosted: Wed Jul 01, 2009 8:28 pm
I'm not being a smartass here, but try pushing the pedal harder
find a quiet backstreet (industrial area on the weekend etc.) and do some "crash stop" tests
PostPosted: Wed Jul 01, 2009 8:40 pm
This space for rent
This is a good habit to get into on a semi-regular basis anyway.
1. You get to test the effectiveness of your brakes in an emergency situation before the situation becomes an emergency.
2. You get practice finding the braking threshold just before locking them up -- this is an important skill to develop.
3. Do it in different weather conditions and get practice emergency braking in the wet, safely.
You might get pinged by the cops if you do it regularly (I did once :D) but if you explain what you're doing, they're cool.
PostPosted: Wed Jul 01, 2009 8:48 pm
Check your brake pads and maybe purchase some new ones if they are getting worn out. the older they are the more likely they are to "go off" and loose ther effectiveness.
Have a Nice Day.
PostPosted: Wed Jul 01, 2009 8:50 pm
and buy standard road ones, not the fancy high performance ones. The high performance ones don't work on road cars where they don't get hot
PostPosted: Wed Jul 01, 2009 9:37 pm
cause i wore them out for u while it was in my gentle loving care. :twisted:
PostPosted: Wed Jul 01, 2009 9:59 pm
I have the same brake setup as you mentioned on my car, and like simon k suggested, try pushing the pedal harder. It's sometimes surprising when you think you are braking hard, but then you really try and the brakes really work. Driving around in normal traffic i find i don't brake very hard because of the people in front of me, and it causes me to sometimes get caught out when i really need to press the brakes, as i'm not used to pressing hard.
Also i highly recommend finding someplace quite and testing your brakes out.
On another note, pads were mentioned as a possible cause of ineffectiveness. So can your disk rotors if they are "glazed" It's probably not very noticeable, but just another thing that adds up.
PostPosted: Wed Jul 01, 2009 10:03 pm
yep i thought my brakes were lacking a bit.. but when you really need them.. it's suprising how easily the fronts lock up!
tim
 Post subject: Discs.
PostPosted: Thu Jul 02, 2009 5:22 am
What size discs are they. If you happen to have the smaller Mk 1 Cooper Disc brakes they were never much good for stopping. 7.5inch and 8.4 inch should work well. Without a booster they will require a bit more push on the pedal to come on Properly but a good booster fitted will make so much difference.
"Let us remove your "SHORTS"
PostPosted: Thu Jul 02, 2009 7:11 am
esoecially if you're swapping in and out of the mini and modern cars, my other half used to reguarly nearly put himself through the windscreen getting out of his Ford and into my VW as the brake pedal was so much higher in my car, the SAAB on the other hand is the exact opposite, ever 6 months in I'd find myself not pushing the pedal hard enough to stop
'62 Morris 850 (Marion)
'69 Vanden Plas Princess 1300
'71 Wolseley 1300
'74 Austin 1300 Countryman
'94 XJ6 Sport 3.2
'04 Rover 75 CDTi
Users browsing this forum: drmini in aust and 286 guests
