Now I've done it! https://www.ausmini.com/forums/viewtopic.php?f=2&t=54825 |
Author: | headgasket [ Fri Jul 03, 2009 9:05 pm ] |
Post subject: | Now I've done it! |
Oh man... I've done some really stupid things in my life, but I think i might have just outdone myself >_<. A long-suffering red clubby is going to be really famous tomorrow. I'll keep it a secret until tomorrow, then I'll post up a pic before I leave the house. Hint: it involves music Edit Sat 4 July: ![]() ![]() ![]() Headed for the Michael Jackson Mass Moonwalk this evening in Martin Place: http://www.facebook.com/group.php?gid=9 ... 389&ref=mf |
Author: | brett [ Fri Jul 03, 2009 10:16 pm ] |
does it include strippers?? |
Author: | GoodnightWalter [ Fri Jul 03, 2009 10:22 pm ] |
brett wrote: does it include strippers??
and midgets? |
Author: | Drexxle [ Fri Jul 03, 2009 10:23 pm ] |
midget strippers dancing in the back of a mini van, disco lights and some doof doof. |
Author: | jasonf [ Sat Jul 04, 2009 10:10 am ] |
Well it's tomorrow????? Wheres the pics of the midget strippers dancing in the back of a mini van with disco lights and some doof doof. ![]() ![]() |
Author: | headgasket [ Sat Jul 04, 2009 1:37 pm ] |
OP edited ![]() Yes it's loud... earplugs, check! |
Author: | headgasket [ Sun Jul 05, 2009 10:14 pm ] |
Pictures: ![]() ![]() ![]() Videos: http://www.youtube.com/watch?v=ofSYiaTHLyw http://www.youtube.com/watch?v=2bZ67Pw44_g 50 YEARS OF LOVE: MINI AND MJ |
Author: | Tombo [ Sun Jul 05, 2009 10:26 pm ] |
jasonf wrote: Well it's tomorrow?????
Wheres the pics of the midget strippers dancing in the back of a mini van with disco lights and some doof doof. ![]() ![]() I might have a van, i might be short, there might be disco lights and doof doof but i am not a stripper. Top effort headgasket, you would have put smiles on a lot of faces ![]() |
Author: | DTrain [ Sun Jul 05, 2009 10:30 pm ] |
hah hear the voice..."your walking backwards, thats all your doing!" |
Author: | headgasket [ Sun Jul 05, 2009 10:33 pm ] |
I must say, driving that car with MJ cranked up is even wierder than usual. I had people following me in formation behind, and people coming up alongside and giving me the thumbs up. I even got requests ![]() I wanted to take a vid with my camera, but it ran out of battery! Typical!!! Any way the sound system specs are: - 1x 2x150W Response amp. - 2x 120W cheapo party speakers (8 ohms) - 1x Marine 12V (110Ah) battery that is still not flat after about 2hrs of - powering the above at full volume - Some 4 gauge cable for carrying 30A to the amp, and speaker cable - A 120A circuitbreaker with built in voltage display so I could keep an eye on the power. - Laptop with winamp for supply the tunes - Car battery + alternator as backup I wasn't sure if the marine battery would hold out for 3 hours, but it did. But then again, I probably wasn't actually doing the full 240 W because I was using 8 ohm speakers instead of 4 (permitted by the amp). Initially I planned to run them in parallel in bridged mono configuration, but it turned out to be loud enough in stereo. But this gives me a very bad idea.... it means I can buy another pair of speakers and run each pair in parallel off the same amp. Some interesting observations: - Was nice to see the batt voltage slump to 11.7 during bass beats and then back up to 12.0 - Switching over to the car battery, the alternator was able to maintain 13.1 - 13.4 V driving at night with the stereo cranked to full volume. - A mini roof can support 2 20kg (?) speakers weight. It dented in a bit to be flat, but popped out when I took the speakers off This car never stops amazing... Buhaha.... Edit: A had a heart attack when I first rocked up to the place. I switched the jumper leads from the car batt to the marine batt, but forgot to watch the polarization. ![]() ![]() Edit2: Reformatted amp specs, theres only 1 amp. |
Author: | Tombo [ Sun Jul 05, 2009 10:41 pm ] |
headgasket wrote: - 2x150W Response amp.
- 2x120W cheapo party speakers (8 ohms) - 1x Marine 12V (110Ah) battery that is still not flat after about 2hrs of - powering the above at full volume - Some 4 gauge cable for carrying 30A to the AMP, and speaker cable - A 120A circuitbreaker with built in voltage display so I could keep an eye on the power. - Laptop with winamp for supply the tunes - Car battery + alternator as backup I wasn't sure if the marine battery would hold out for 3 hours, but it did. Buhaha.... Thats a good effort. In my van there are 3 amps collectively 2000w 1 x 700cca battery 85A alternator (63A couldn't keep up) A 1 farad cap Not running i had the stereo on for about 8 hours at about 1/3 - 1/2 volume and the drain got to about 11V. It started the next day. Your system should well outdo that, and probably push more SPL ![]() |
Author: | headgasket [ Sun Jul 12, 2009 9:51 pm ] |
Check this out: http://www.mediavr.com/flash/mjackson.htm |
Author: | Fiji [ Mon Jul 13, 2009 6:16 am ] |
pretty cool ![]() seems as though everyone had a good time |
